在电子设备的设计中,显示模块是至关重要的组成部分。今天,我们来深入了解Newhaven Display推出的NHD - C0220AU - FSW - FTS COG(Chip - on - Glass)液晶显示模块,看看它有哪些特性和优势,以及在实际应用中需要注意的地方。
NHD - C0220AU - FSW - FTS是一款具有特定功能和特性的液晶显示模块,其型号各部分含义如下:
它拥有2行×20字符的显示规格,能够清晰地显示文本信息,满足一般的显示需求。
内置NT7605控制器,为显示模块的稳定运行提供了保障。不过需要注意的是,该控制器的忙标志可能并非总是响应及时,在设计时需要添加足够的延迟和/或超时检查程序,以确保在忙标志未清除时仍能继续操作。
采用3.3V电源供电,具有较低的功耗,适合多种电子设备的应用。
采用1/16 duty,1/5 bias的驱动方式,有助于提高显示的稳定性和对比度。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | GND | Power Supply | Ground |
| 2 | V5 | Adj Power Supply | Contrast voltage adjustment (~0.1V) |
| 3 | VDD | Power Supply | VDD = 3.3V |
| 4 | RS | MPU | Register Select: 0 = Instruction, 1 = Data |
| 5 | R/W | MPU | Read / Write select: 0 = Write, 1 = Read |
| 6 | E | MPU | Read/Write start signal (Schmitt trigger input) |
| 7 - 10 | DB0 – DB3 | MPU | Low 4 tri - state bi - directional data bus lines. Not used in 4 - bit mode. |
| 11 - 14 | DB4 – DB7 | MPU | High 4 tri - state bi - directional data bus lines. |
推荐的LCD连接器为2.0mm间距、14引脚,可焊接到PCB上,也可选用JST p/n: PHR - 14;背光连接器为A和K引脚,可与电线或PCB焊接。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | 0 | 25 | +50 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | 25 | +80 | ⁰C |
| Supply Voltage | VDD | 3.2 | 3.3 | 3.4 | V | |
| Supply Current | IDD | VDD = 3.3V | 1.0 | mA | ||
| Supply for LCD (contrast) | Vlcd | VLCD = VDD - V5 | 3.1 | 3.2 | 3.3 | V |
| “H” Level input | Vih | 0.8VDD | VDD | V | ||
| “L” Level input | Vil | 0 | 0.2VDD | V | ||
| “H” Level output | Voh | VDD - 0.6 | V | |||
| “L” Level output | Vol | GND + 0.6 | V | |||
| Backlight Supply Voltage | VLED | 3.0 | 3.1 | 3.2 | V | |
| Backlight Supply Current | Iled | VLED = 3.1V | 30 | 40 | 60 | mA |
| Viewing Angle - Vertical | AV | Cr ≥2 | - 20 | +60 | ⁰ | |
| Viewing Angle - Horizontal | AH | Cr ≥2 | - 50 | +50 | ⁰ | |
| Contrast Ratio | Cr | 25⁰C | 9 | 15 | ||
| Response Time (rise) | Tr | 150 | 200 | ms | ||
| Response Time (fall) | Tr | 250 | 400 | ms |
该显示模块提供了一系列的指令,用于控制显示内容、光标位置等操作。例如,“Display Clear”指令(代码为0 0 0 0 0 0 0 0 0 1)可清除整个显示区域,并将显示恢复到初始状态;“Display ON/OFF”指令可控制显示、光标和字符闪烁的开关状态。
| 显示模块的字符地址码如下: | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
| 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 | |||||||||
| 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 |
这些地址码用于确定字符在显示区域中的位置。
在读取操作中,需要关注一些关键的时序参数,如使能周期时间、使能上升/下降时间、RS和R/W的建立时间等。这些参数对于确保数据的准确读取至关重要。
写入操作同样有其特定的时序要求,包括使能周期时间、使能高电平脉冲宽度、数据输出延迟等。在设计电路时,必须严格按照这些时序要求进行设计,以保证数据的正确写入。
文档中提供了一个初始化程序示例,通过一系列的指令设置来初始化显示模块。例如,先进行唤醒操作,然后进行功能设置、显示开关设置、输入模式设置等。这个示例程序可以为工程师在实际应用中提供参考。
该显示模块经过了多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抵抗、振动测试和静电测试等。这些测试确保了产品在不同环境条件下的可靠性和稳定性。
在使用LCDs/LCMs时,需要注意一些事项,具体可参考www.newhavendisplay.com/specs/precautions.pdf。同时,关于产品的保修信息和条款可查看http://www.newhavendisplay.com/index.php?main_page=terms。
总的来说,NHD - C0220AU - FSW - FTS COG液晶显示模块具有丰富的功能和良好的性能,适用于多种电子设备的显示需求。在设计应用时,工程师需要充分了解其特性和要求,以确保产品的稳定运行。大家在实际应用中有没有遇到过类似显示模块的问题呢?欢迎在评论区分享交流。
