在电子工程领域,逆变器模块对于驱动各类电机至关重要。今天,我们将详细探讨FSB50450S Motion SPM® 5系列模块,它是一款先进的逆变器模块,为交流感应、无刷直流(BLDC)和永磁同步(PMSM)电机提供了全功能、高性能的逆变器输出级。
文件下载:FSB50450S.pdf
Fairchild Semiconductor的FSB50450S如今已成为ON Semiconductor的一部分。由于系统集成需求,部分Fairchild可订购的零件编号需要更改,原编号中的下划线(_)将改为破折号(-)。大家可访问ON Semiconductor网站(www.onsemi.com)核实更新后的设备编号。
| 参数 | 条件 | 额定值 | 单位 |
| (V_{DSS}) (每个MOSFET漏源电压) | - | 500 | V |
| (I{D25}) (每个MOSFET连续漏极电流, (T{C}=25^{circ}C) ) | - | 1.5 | A |
| (I{D80}) (每个MOSFET连续漏极电流, (T{C}=80^{circ}C) ) | - | 1.1 | A |
| (I{DP}) (每个MOSFET峰值漏极电流, (T{C}=25^{circ}C) , (PW < 100 mu s) ) | - | 3.0 | A |
| (P{D}) (每个MOSFET最大功耗, (T{C}=25^{circ}C) ) | - | 10 | W |
| (V{CC}) (控制电源电压,施加于 (V{CC}) 和COM之间) | - | 20 | V |
| (V_{BS}) (高端偏置电压,施加于VB和VS之间) | - | 20 | V |
| (V_{IN}) (输入信号电压,施加于IN和COM之间) | - | -0.3 ~ (V_{CC} + 0.3) | V |
该模块共有23个引脚,每个引脚都有特定的功能,例如:
| 参数 | 条件 | 最小值 | 典型值 | 最大值 | 单位 |
| (BV_{DSS}) (漏源击穿电压) | (V{IN} = 0V) , (I{D} = 250 mu A) | 500 | - | - | V |
| (I_{DSS}) (零栅压漏极电流) | (V{IN} = 0V) , (V{DS} = 500V) | - | - | 250 | (mu A) |
| (R_{DS(on)}) (静态漏源导通电阻) | (V{CC} = V{BS} = 15V) , (V{IN} = 5V) , (I{D} = 0.5A) | - | 1.9 | 2.4 | (Omega) |
| (V_{SD}) (漏源二极管正向电压) | (V{CC} = V{BS} = 15V) , (V{IN} = 0V) , (I{D} = -0.5A) | - | - | 1.2 | V |
| (t_{ON}) (开关时间) | (V{PN} = 300V) , (V{CC} = V{BS} = 15V) , (I{D} = 0.5A) , (V_{IN} = 0V to 5V) ,感性负载 (L = 3mH) | - | 1152 | - | ns |
| (t_{OFF}) | - | - | 600 | - | ns |
| (t_{rr}) | - | - | 185 | - | ns |
| (E_{ON}) | - | - | 85 | - | (mu J) |
| (E_{OFF}) | - | - | 11 | - | (mu J) |
| (RBSOA) (反向偏置安全工作区) | (V{PN} = 400V) , (V{CC} = V{BS} = 15V) , (I{D} = I{DP}) , (V{DS} = BV{DSS}) , (T{J} = 150^{circ}C) | - | 全方形 | - | - |
| (I{QCC}) ( (V{CC}) 静态电流) | (V{CC} = 15V) , (V{IN} = 0V) ,施加于 (V_{CC}) 和COM之间 | - | - | 160 | (mu A) |
| (I{QBS}) ( (V{BS}) 静态电流) | (V{BS} = 15V) , (V{IN} = 0V) ,施加于 (V{B(U)} - U) , (V{B(V)} - V) , (V_{B(W)} - W) 之间 | - | - | 100 | (mu A) |
| (UV_{CCD}) (低侧欠压保护检测电平) | (V_{CC}) | 7.4 | 8.0 | 9.4 | V |
| (UV{CCR}) ( (V{CC}) 欠压保护复位电平) | - | 8.0 | 8.9 | 9.8 | V |
| (UV_{BSD}) (高端欠压保护检测电平) | (V_{BS}) | 7.4 | 8.0 | 9.4 | V |
| (UV{BSR}) ( (V{BS}) 欠压保护复位电平) | - | 8.0 | 8.9 | 9.8 | V |
| (V_{IH}) (导通阈值电压) | 逻辑高电平,施加于IN和COM之间 | 3.0 | - | - | V |
| (V_{IL}) (关断阈值电压) | 逻辑低电平 | - | - | 0.8 | V |
| (I_{IH}) (输入偏置电流) | (V_{IN} = 5V) ,施加于IN和COM之间 | - | 10 | 20 | (mu A) |
| (I_{IL}) | (V_{IN} = 0V) | - | - | 2 | (mu A) |
| (V_{PN}) (电源电压,施加于P和N之间) | - | - | 300 | 400 | V |
| (V{CC}) (控制电源电压,施加于 (V{CC}) 和COM之间) | - | 13.5 | 15.0 | 16.5 | V |
| (V{BS}) (高端偏置电压,施加于 (V{B}) 和 (V_{S}) 之间) | - | 13.5 | 15.0 | 16.5 | V |
| (V_{IN(ON)}) (输入导通阈值电压,施加于IN和COM之间) | - | 3.0 | - | (V_{CC}) | V |
| (V_{IN(OFF)}) (输入关断阈值电压) | - | 0 | - | 0.6 | V |
| (t_{dead}) (防止桥臂短路的消隐时间) | (V{CC} = V{BS} = 13.5 ~ 16.5V) , (T_{J} leq 150^{circ}C) | 1 | - | - | (mu s) |
| (f_{PWM}) (PWM开关频率) | (T_{J} leq 150^{circ}C) | - | 15 | - | kHz |
| (T_{C}) (外壳温度) | (T_{J} leq 150^{circ}C) | -20 | - | 100 | °C |
该模块适用于小功率交流电机驱动器的三相逆变器驱动。
FSB50450S Motion SPM® 5系列模块凭借其丰富的特性和良好的电气性能,为小功率交流电机驱动提供了可靠的解决方案。电子工程师在使用该模块时,需根据实际应用需求,合理选择工作参数,并注意电路设计中的各项细节,以确保系统的稳定运行。大家在实际应用中是否遇到过类似模块的使用问题呢?欢迎在评论区分享交流。
