在电力电子设计领域,栅极驱动器是驱动功率开关管的关键组件,其性能直接影响到整个系统的效率和稳定性。安森美(onsemi)的NCP5156x系列隔离双通道栅极驱动器以其出色的性能和灵活的配置,成为众多工程师的首选。本文将详细介绍NCP5156x评估板的使用方法,帮助工程师更好地了解和应用这一产品。
文件下载:NCP-NCV51561TO2474LGEVB.pdf
NCP5156x是一系列隔离双通道栅极驱动器,具有4.5A/9A的源极和漏极峰值电流,专为快速开关设计,可用于驱动功率MOSFET和SiC MOSFET功率开关。该系列驱动器具有短且匹配的传播延迟,输入到每个输出之间有5 kVRMS的内部电流隔离,两个输出驱动器之间有内部功能隔离,允许高达1500 VDC的工作电压。此外,NCP5156x还提供独立的欠压锁定(UVLO)保护和死区时间调整功能。
使用NCP51561评估板(EVB)时,可通过安装的测试点或在连接器中安装电线来进行外部连接。主要连接包括模拟电源电压、输入信号、输出负载和监测设备。
| 评估板的跳线设置可根据不同的应用需求进行调整,具体设置如下表所示: | Jumper | Jumper Setting Options | Default Setting | |
| J4 - INA | Option1 | Jumper not installed, INA/PWM signal provided by external signal and this pin is default low if left open | Option1 | |
| Option2 | Jumper on J4 - INA - 2 and J4 - INA - 3 set INA low | |||
| Option3 | Jumper on J4 - INA - 2 and J4 - INA - 1 set INA high | |||
| J5 - INB | Option1 | Jumper not installed, INB signal provided by external signal and this pin is default low if left open | Option1 | |
| Option2 | Jumper on J5 - INB - 2 and J5 - INB - 3 set INB low | |||
| Option3 | Jumper on J5 - INB - 2 and J5 - INB - 1 set INB high | |||
| J11 - ANB | Option1 | Jumper on J11 - ANB - 2 and J11 - ANB - 4 set ANB low for dual input mode | Option1 | |
| Option2 | Jumper on J11 - ANB - 1 and J11 - ANB - 3 set ANB high for single input (PWM) mode | |||
| J15 - ENA/DIS | Option1 | Jumper not installed, DISABLE signal provided by external signal and this pin is default low if left open | Option2 | |
| Option2 | Jumper on J15 - ENA/DIS - 2 and J15 - ENA/DIS - 3 set DISABLE low (Or ENABLE low) | |||
| Option3 | Jumper on J15 - ENA/DIS - 2 and J15 - ENA/DIS - 1 set DISABLE high (Or ENABLE high) | |||
| T.P1 | Option1 | Jumper on T.P1 - 1 and T.P1 - 2 for half - bridge application | Option2 | |
| Option2 | Jumper off T.P1 - 1 and T.P1 - 2 for bench test. | |||
| T.P2 | Option1 | Jumper on T.P2 - 1 and T.P2 - 2 and jumper on J16 - 2 and J16 - 4 for single power supply (VCCA = VCCB) | Option1 | |
| Option2 | Jumper on T.P2 - 1 and T.P2 - 2 and and jumper on J16 - 1 and J16 - 3 for VCCA bootstrap supply | |||
| T.P3 | Option1 | Jumper on T.P3 - 1 and T.P3 - 2 for single power supply (e.g. VSSA = VSSB) | Option1 | |
| Option2 | Jumper off T.P3 - 1 and T.P3 - 2 for dual power supply | |||
| T.P4 T.P5 | Option1 | Jumper on T.P4 - 1 and T.P4 - 2 for negative gate drive bias. | Option2 | |
| Option2 | Jumper on T.P5 - 1 and T.P5 - 2 for unipolar gate drive. | |||
| T.P6 T.P7 | Option1 | Jumper on T.P6 - 1 and T.P6 - 2 for negative gate drive bias. | Option2 | |
| Option2 | Jumper on T.P7 - 1 and T.P7 - 2 for unipolar gate drive. |
NCP51561允许通过ANB引脚改变输入信号引脚配置,提供单输入 - 双输出或双输入 - 双输出等工作模式。通过实验波形可以观察到ANB功能在有和没有死区时间控制时的不同表现。
SiC MOSFET需要更高的正栅极驱动电压(+20 V)和负关断栅极电压( - 2 V至 - 6 V)。可通过连接开关源引脚到Zener二极管或VSS引脚来选择单极或负偏置输出驱动类型。
在25°C时,当供应电压(VCCA和VCCB)为12 V时,源极和漏极峰值电流驱动能力分别约为4.0 A和10 A。
NCP51561的ESD保护组件由多个二极管组成,说明了该器件的绝对最大额定值。
安森美NCP5156x隔离双通道栅极驱动器评估板为工程师提供了一个方便的平台,用于评估和验证该系列驱动器的性能。通过合理的跳线设置、正确的上电和下电步骤以及全面的性能测试,工程师可以深入了解NCP5156x的特点和优势,为实际应用提供有力的支持。在使用评估板时,务必遵循相关的安全注意事项,确保测试过程的安全和可靠。你在使用NCP5156x评估板时遇到过哪些问题?又是如何解决的呢?欢迎在评论区分享你的经验。
