在电子设计领域,高性能、小尺寸的器件一直是工程师们追求的目标。onsemi 的 NL17SG04 单逆变器就是这样一款引人注目的产品,它以先进的技术和出色的性能,为各类电子设备的设计提供了强大的支持。
文件下载:NL17SG04-D.PDF
NL17SG04 是一款先进的高速 CMOS 逆变器,采用超小尺寸封装,具有卓越的性能和广泛的应用前景。其输入结构能够在高达 3.6V 的电压下提供保护,确保了设备的稳定性和可靠性。
| SOT−953 | SC−88A | UDFN6 | |
| 1 | A | NC | NC |
| 2 | GND GND | A | A |
| 3 | NC NC | GND | GND |
| 4 | Y | Y | Y |
| 5 | V CC V CC | V CC | NC |
| 6 | V CC |
| A Input | Y Output |
| L | H |
| H | L |
| Symbol | Value | Unit | ||
| VCC | DC Supply Voltage | -0.5 to +4.3 | V | |
| DC Input Voltage | -0.5 to +4.3 | V | ||
| VOUT | DC Output Voltage | Tri-State Mode (Note 1) Power-Down Mode $left(V_{C C}=0 ~Vright)$ | -0.5 to $V_{CC}+0.5$ -0.5 to +4.3 -0.5 to +4.3 | |
| DC Input Diode Current | VIN < GND | -20 | mA | |
| DC Output Diode Current | VOUT < GND | -20 | mA | |
| lOUT | DC Output Source/Sink Current | +20 | mA | |
| DC Supply Current Per Supply Pin or Ground Pin | +20 | mA | ||
| TSTG | -65 to +150 | °C | ||
| TL | Lead Temperature, 1 mm from Case for 10 Seconds | 260 | °C | |
| TJ | +150 | °C | ||
| θJA | Thermal Resistance (Note 2) | SC-88A | °CW | |
| SOT-953 UDFN6 | 377 254 | |||
| PD | SC-88A SOT-953 UDFN6 | 332 491 812 | mW | |
| MSL | Moisture Sensitivity | Level 1 | ||
| FR | UL 94 V-0 @ 0.125 in | |||
| VESD | ESD Withstand Voltage (Note 3) | Human Body Model | 2000 | V |
| Charged Device Model | 1000 | |||
| LATCHUP | Latchup Performance (Note 4) | ±100 | mA |
| Symbol | Parameter | Min | Max | Unit | |
| V CC | Positive DC Supply Voltage | 0.9 | 3.6 | V | |
| V IN | Digital Input Voltage | 0 | 3.6 | V | |
| V OUT | Output Voltage | Active Mode (High or Low State) | 0 0 | V | V |
| Tri−State Mode (Note 1) Power Down Mode (V CC = 0 V) | 0 | CC 3.6 3.6 | |||
| T A | Operating Free−Air Temperature | −55 | +125 | ° C | |
| t r , t f | Input Transition Rise or Fall Rate | V CC = 3.3 V ± 0.3 V | 0 | 10 | nS/V |
由于文档中直流电气特性表格部分内容不太清晰,这里暂不详细列出。但需要注意的是,产品的参数性能在电气特性中是针对特定测试条件给出的,如果在不同条件下运行,产品性能可能会有所不同。
| Symbol | Parameter | Test Condition | VCC (V) | Min | Typ | Max | Min | Max | Unit |
| Propagation Delay, A to Y | CL = 10 pF, RL = 1 M | 0.9 | 39.8 | ns | |||||
| tPLH, tPHL | 1.1 to 1.3 | 8.7 | 21.9 | 25.3 | |||||
| 1.4 to 1.6 | 4.9 | 8.5 | 10.0 | ||||||
| 1.65 to 1.95 | 3.8 | 6.2 | 6.7 | ||||||
| 2.3 to 2.7 | 2.6 | 3.9 | 4.4 | ||||||
| 3.0 to 3.6 | 2.1 | 3.1 | - | 3.7 | |||||
| CL = 15 pF, RL = 1 M | 0.9 | 40.9 | ns | ||||||
| 1.1 to 1.3 | 8.9 | 22.6 | 26.1 | ||||||
| 1.4 to 1.6 | 5.4 | 9.3 | - | 11.2 | |||||
| 1.65 to 1.95 | - | 4.2 | 6.9 | - | 7.1 | ||||
| 2.3 to 2.7 | 2.8 | 4.4 | 5.0 | ||||||
| 3.0 to 3.6 | 2.3 | 3.4 | 3.9 | ||||||
| CL = 30 pF, RL = 1 M | 0.9 | - | 44.5 | - | ns | ||||
| 1.1 to 1.3 | 9.5 | 24.6 | 28.3 | ||||||
| 1.4 to 1.6 | 7.4 | 13.1 | 15.9 | ||||||
| 1.65 to 1.95 | - | 5.6 | 9.2 | - | 9.6 | ||||
| 2.3 to 2.7 | - | 3.7 | 5.7 | 6.1 | |||||
| 3.0 to 3.6 | 2.9 | 4.4 | 4.8 | ||||||
| CIN | Input Capacitance | 0 to 3.6 | 3 | pF | |||||
| CPD | Capacitance (Note 5) | Power Dissipation f = 10 MHz | 0.9 to 3.6 | 4 | pF |
从交流电气特性可以看出,NL17SG04 在不同的负载电容和电源电压条件下,传播延迟等参数会有所变化。工程师在设计电路时,需要根据实际需求选择合适的工作条件。
| Device | Marking | Pin 1 Quadrant (See below) | Package | Shipping † |
| NL17SG04DFT2G | AP | 3 | SC−88A | 3000 / Tape & Reel |
| NL17SG04P5T5G | V | 2 | SOT−953 | 8000 / Tape & Reel |
| NL17SG04MU1TCG | 4 | 3 | UDFN6 1.45 x 1.0 | 3000 / Tape & Reel |
| NL17SG04MU3TCG | 5 | 3 | UDFN6 1.0 x 1.0 | 3000 / Tape & Reel |
文档中详细给出了 UDFN6(1.45x1.0、1x1)和 SOT - 953 三种封装的机械尺寸和相关说明,包括尺寸公差、引脚尺寸等信息,这对于 PCB 设计和焊接非常重要。同时,还提供了推荐的焊接脚印和通用标记图,方便工程师进行实际操作。
onsemi 的 NL17SG04 单逆变器以其高性能、小尺寸和丰富的特性,为电子工程师提供了一个优秀的选择。在实际设计中,工程师需要根据具体的应用场景和需求,合理选择封装形式、工作条件等参数,以充分发挥该器件的优势。同时,要注意遵守器件的最大额定值和推荐工作条件,确保设备的稳定性和可靠性。
你在使用 NL17SG04 或类似器件时,是否遇到过一些特殊的问题或挑战呢?欢迎在评论区分享你的经验和见解。
