在电子设计领域,数据总线间的高效通信至关重要。今天我们就来深入了解一款能实现异步双向通信的八进制总线收发器——MC74ACT640,看看它有哪些独特的性能和特点。
文件下载:MC74ACT640-D.PDF
MC74ACT640主要用于数据总线间的异步双向通信。当 (T / overline{R}=HIGH) 时,数据从总线 (overline{A}) 传输到总线B;当 (T / overline{R}=LOW) 时,数据从总线 (overline{B}) 传输到总线A。此外,通过使能输入(OE)可以禁用该设备,从而有效隔离总线。
| PIN | FUNCTION |
| A 0 - A 7 | 侧A输入或三态输出 |
| OE | 输出使能输入 |
| T/R | 发送/接收输入 |
| B 0 - B 7 | 侧B输入或三态输出 |
| OE | T/R | Applied Inputs | Valid Direction I/P → O/P | Output |
| H | X | X | X | X |
| L | H | H | A to B | L |
| L | H | L | A to B | H |
| L | L | H | B to A | L |
| L | L | L | B to A | H |
从真值表中我们可以清晰地看到,在不同的OE和T/R输入状态下,数据的传输方向和输出状态是如何变化的。这对于我们在设计电路时正确控制数据流向非常关键。大家在实际应用中有没有遇到过因为真值表理解错误而导致的电路故障呢?
| Symbol | Parameter | Value | Unit |
| VCC | DC Supply Voltage (Referenced to GND) | -0.5 to +6.5 | V |
| VIN | DC Input Voltage (Referenced to GND) | -0.5 to VCC +0.5 | V |
| VOUT | DC Output Voltage (Referenced to GND) (Note 1) | -0.5 to VCC +0.5 | V |
| lK | DC Input Diode Current | +20 | mA |
| lok | DC Output Diode Current | +50 | mA |
| OUT | DC Output Sink/Source Current | +50 | mA |
| Icc | DC Supply Current, per Output Pin | +50 | mA |
| IGND | DC Ground Current, per Output Pin | ±100 | mA |
| TSTG | Storage Temperature Range | -65 to +150 | °C |
| TL | Lead temperature, 1 mm from Case for 10 Seconds | 260 | °C |
| TJ | Junction Temperature Under Bias | 140 | °C |
| θJA | Thermal Resistance (Note 2) | 96 | °C/W |
| MSL | Moisture Sensitivity | Level 1 | |
| FR | Flammability Rating Oxygen Index: 30% - 35% | UL 94 V - 0 @ 0.125 in | |
| VESD | ESD Withstand Voltage Human Body Model (Note 3) Charged Device Model (Note 4) | > 2000 1000 | V |
| Latchup | Latchup Performance Above VCC and Below GND at 85°C (Note 5) | ±100 | mA |
这些最大额定值为我们在使用该器件时提供了安全边界。如果超过这些极限值,可能会损坏器件,影响其功能和可靠性。那么在实际设计中,我们该如何确保这些参数不被超出呢?
| Symbol | Parameter | Min | Typ | Max | Unit | |
| V CC | DC Input Voltage (Referenced to GND) | 4.5 | 5.5 | V | ||
| V in, V out | DC Input Voltage, Output Voltage (Referenced to GND) | 0 | V CC | V | ||
| T A | Operating Temperature, All Package Types | −40 | 25 | +85 | ° C | |
| t r, t f | Input Rise and Fall Time (Note 7) | V CC = 4.5 V V CC = 5.5 V | 0 0 | 10 8.0 | 10 8.0 | ns/V |
| I OH | Output Current − High | −24 | mA | |||
| I OL | Output Current − Low | 24 | mA |
在推荐工作条件下使用该器件,可以保证其正常的功能和可靠性。当我们在不同的应用场景中,如何根据这些条件来调整电路设计呢?
文档中详细给出了直流特性和交流特性的参数,包括输入输出电压、电流、传播延迟等。这些参数对于我们评估器件在不同工作条件下的性能非常重要。例如,传播延迟参数 (t{PLH}) 和 (t{PHL}) 可以帮助我们确定信号在器件中的传输时间,从而优化电路的时序设计。大家在设计电路时,有没有特别关注过这些特性参数呢?
| Symbol | Parameter | Value Typ | Unit | Test Conditions |
| C IN | Input Capacitance | 4.5 | pF | V CC = 5.0 V |
| C I/O | Input/Output Capacitance | 15 | pF | V CC = 5.0 V |
| C PD | Power Dissipation Capacitance | 45 | pF | V CC = 5.0 V |
电容特性会影响器件的高频性能和功耗。在高频电路设计中,我们需要考虑这些电容对信号传输的影响。
| Device | Marking | Package | Shipping † |
| MC74ACT640DWR2G | ACT640 | SOIC−20 | 1000 / Tape & Reel |
在订购该器件时,我们可以根据实际需求选择合适的封装和包装方式。同时,还可以参考文档中关于封装尺寸和焊接要求的详细信息,确保器件的正确安装和使用。
文档中提供了SOIC - 20 WB封装的机械尺寸和推荐的焊接脚印。这些信息对于我们进行电路板设计和焊接工艺非常重要。在进行电路板设计时,我们需要严格按照这些尺寸要求来布局,以确保器件的正常安装和良好的电气连接。
综上所述,MC74ACT640是一款功能强大、性能稳定的八进制三态反相收发器。在电子设计中,我们可以根据其特性和参数,合理地将其应用于各种数据总线通信场景中。同时,在使用过程中要严格遵守其最大额定值和推荐工作条件,以保证器件的可靠性和稳定性。大家在使用这款器件时,有没有什么独特的经验或遇到过什么问题呢?欢迎在评论区分享。
