在电子设计领域,移位寄存器是一种常用的数字电路元件,它能够实现数据的串行和并行传输,广泛应用于各种数字系统中。今天,我们将深入探讨安森美(onsemi)的MC74HC597A,这是一款高性能的8位串行或并行输入/串行输出移位寄存器,具有输入锁存功能。
文件下载:MC74HC597A-D.PDF
MC74HC597A采用高性能硅栅CMOS技术,其引脚排列与LS597相同,输入兼容标准CMOS输出,通过上拉电阻还能兼容LSTTL输出。该器件由一个8位输入锁存器和一个8位移位寄存器组成,数据既可以并行加载到输入锁存器,也可以串行加载到移位寄存器。它与HC589A功能相似,但HC589A是三态器件。
MC74HC597A的功能表详细描述了不同输入条件下的器件操作,包括复位、并行数据加载、串行数据移位等功能。例如,当复位信号为低电平时,移位寄存器被复位为低电平;当串行移位/并行加载信号为高电平时,移位寄存器允许串行移位数据;当该信号为低电平时,移位寄存器接受来自输入锁存器的并行数据。
| Operation | Inputs | Resulting Function | |||||||
| Re- set | Serial Shift/ Parallel Load | Latch Clock | Shift Clock | Serial Input S A | Parallel Inputs A−H | Latch Contents | Shift Register Contents | Output Q H | |
| Reset shift register | L | X | L, H, | X | X | X | U | L | L |
| Reset shift register; load parallel data into data latch | L | X | X | X | a−h | a−h | L | L | |
| Load parallel data into data latch | H | H | L,H, | X | a−h | a−h | U | U | |
| Transfer latch contents to shift register | H | L | L, H, | X | X | X | U | LR N SR N | LR H |
| Contents of data latch and shift register are unchanged | H | H | L, H, | L,H, | X | X | U | U | U |
| Load parallel data into data latch and shift register | H | L | X | X | a−h | a−h | a−h | h | |
| Shift serial data into shift register | H | H | X | D | X | * | SR A = D; SR N SR N + 1 | SR G SR H | |
| Load parallel data into data latch and shift serial data in- to shift register | H | H | D | a−h | a−h | SR A = D; SR N SR N + 1 | SR G SR H |
注:LR = 锁存寄存器内容,a−h = 并行数据输入A−H处的数据,U = 保持不变,SR = 移位寄存器内容,D = 串行数据输入(S_{A})处的数据(L, H),X = 无关项,(*) = 取决于锁存时钟输入
器件的最大额定值规定了其正常工作的极限条件,包括电源电压、输入电压、输出电压、输入电流、输出电流等参数。例如,电源电压的范围为 -0.5V至 +6.5V,输入电压范围为 -0.5V至 (V_{CC}+0.5V) 等。超过这些额定值可能会损坏器件,影响其可靠性。
| Symbol | Parameter | Value | Unit |
| (V_{CC}) | DC Supply Voltage | –0.5 to +6.5 | V |
| (V_{IN}) | DC Input Voltage | –0.5 to (V_{CC}+0.5) | V |
| (V_{OUT}) | DC Output Voltage | –0.5 to (V_{CC}+0.5) | V |
| (I_{IN}) | DC Input Current, per Pin | 20 | mA |
| (I_{OUT}) | DC Output Current, per Pin | 25 | mA |
| (I_{CC}) | DC Supply Current, (V_{CC}) and GND Pins | 50 | mA |
| (I_{IK}) | Input Clamp Current ((V{IN}< 0) or (V{IN}> V_{CC})) | 20 | mA |
| (I_{OK}) | Output Clamp Current ((V{OUT}< 0) or (V{OUT}> V_{CC})) | 20 | mA |
| (T_{STG}) | Storage Temperature | –65 to +150 | C |
| (T_{L}) | Lead Temperature, 1 mm from Case for 10 Seconds | 260 | C |
| (T_{J}) | Junction Temperature Under Bias | 150 | C |
| (R_{JA}) | Thermal Resistance (Note 1) | SOIC−16: 126 QFN16: 118 TSSOP−16: 159 |
C/W |
| (P_{D}) | Power Dissipation in Still Air at 25C | SOIC−16: 995 QFN16: 1062 TSSOP−16: 787 |
mW |
| MSL | Moisture Sensitivity Level | 1 | |
| FR | Flammability Rating | Oxygen Index: 28 to 34, UL 94 V−0 @ 0.125 in | |
| (V_{ESD}) | ESD Withstand Voltage (Note 2) | Charged Device Model: 2000 Human Body Model: N/A |
V |
推荐工作条件给出了器件正常工作的最佳参数范围,包括电源电压、输入输出电压、工作温度、输入上升和下降时间等。例如,电源电压推荐范围为2.0V至6.0V,工作温度范围为 -55°C至 +125°C。在这些条件下,器件能够发挥最佳性能。
| Symbol | Parameter | Min | Max | Unit |
| (V_{CC}) | DC Supply Voltage (Referenced to GND) | 2.0 | 6.0 | V |
| (V{in}, V{out}) | DC Input Voltage, Output Voltage (Referenced to GND) | 0 | (V_{CC}) | V |
| (T_{A}) | Operating Temperature, All Package Types | – 55 | + 125 | C |
| (t{r}, t{f}) | Input Rise and Fall Time | (V{CC}= 2.0 V): 1000 (V{CC}= 3.0 V): 600 (V{CC}= 4.5 V): 500 (V{CC}= 6.0 V): 400 |
ns |
直流电气特性描述了器件在直流状态下的输入输出电压、电流等参数。例如,最小高电平输入电压 (V{IH}) 和最大低电平输入电压 (V{IL}) 随电源电压的变化而变化;最小高电平输出电压 (V{OH}) 和最大低电平输出电压 (V{OL}) 也与电源电压和输出电流有关。
交流电气特性包括最大时钟频率、传播延迟时间、输出转换时间等参数。这些参数反映了器件在交流信号下的性能,例如最大时钟频率决定了器件的工作速度,传播延迟时间影响信号的传输延迟。
MC74HC597A提供多种封装形式,包括SOIC - 16、TSSOP - 16和QFN16。不同封装的尺寸和特性有所不同,用户可以根据实际需求选择合适的封装。订购时,需要注意器件的标记、封装和发货数量等信息。
MC74HC597A是一款功能强大、性能稳定的8位移位寄存器,具有多种工作模式和良好的电气特性。在实际应用中,工程师可以根据具体需求灵活配置其输入输出,实现数据的串行和并行传输。同时,在设计过程中,需要严格遵循器件的最大额定值和推荐工作条件,以确保器件的可靠性和稳定性。你在使用类似移位寄存器时遇到过哪些问题呢?欢迎在评论区分享你的经验。
