在电子工程领域,步进电机的应用十分广泛,而合适的驱动评估板对于电机的稳定运行和性能发挥至关重要。今天我们就来详细了解一下ROHM的BD63xxxEFV-EVK-001评估板。
这款评估板适用于ROHM的步进电机驱动器BD63715AEFV、BD63725BEFV、BD63525AEFV、BD63511EFV和BD63521EFV。通过给电机驱动器的VCC供电以及为控制信号提供5V电源,就可以驱动电机。还能使用外部开关设置驱动/停止和励磁模式。输入接口采用CLK - IN驱动类型,励磁模式通过内置DAC支持FULL STEP、HALF STEP、QUATER STEP、1/8 STEP、1/16 STEP模式。
| Part No. | Max Voltage [V] | Voltage Range (DC) [V] | Max Current (Peak) [A/Phase] | FULL | Half | Quarter | 1/8 | 1/16 |
| BD63715AEFV | 36 | 19 to 28 | 2.0 | ○ | ○ | ○ | ||
| BD63725BEFV | 36 | 8 to 28 | 3.0 | ○ | ○ | ○ | ||
| BD63525AEFV | 36 | 8 to 28 | 3.0 | ○ | ○ | ○ | ○ | |
| BD63511EFV | 36 | 8 to 28 | 1.5 | ○ | ○ | ○ | ○ | |
| BD63521EFV | 36 | 8 to 28 | 2.5 | ○ | ○ | ○ | ○ |
这些步进电机驱动器的供电电压范围在8V - 28V或9V - 28V,电机驱动电流可达3.0A,励磁模式支持FULL STEP、HALF STEP、QUATER STEP、1/8 STEP、1/16 STEP模式。
评估板上有多个开关(SW1 - SW7),还有输出端子和电源接口等,如DC Supply for VCC和DC supply for setting to control voltage (5V) 等。
驱动器BD63XXXEFV有多个引脚,每个引脚都有特定的功能。例如,GND为接地端子,OUT1B和OUT1A为H桥输出端子,VCC1和VCC2为电源供应端子等。详细的引脚功能如下表所示:
| Pin No. | Pin name | Function | Pin No. | Pin name | Function |
| 1 | GND | Ground terminal | 15 | CLK | electrical angle Clock input terminal for advancing the |
| 2 | OUT1B | H bridge output terminal | 16 | CW_CCW | Motor rotating direction setting |
| 3 | RNF1 | Connection terminal of resistor for output current detection | 17※1 | TEST (Used by connecting with GND) terminal | Terminal for testing |
| 4 | RNF1S | Input terminal of current detection comparator | 18 | MODE0 | Motor excitation mode setting terminal |
| 5 | OUT1A | H bridge output terminal | 19 | MODE1 | Motor excitation mode setting terminal |
| 6 | NC | Non connection | 20 | ENABLE | Output enable terminal |
| 7 | VCC1 | Power supply terminal | 21 | NC | Non connection |
| 8 | NC | Non connection | 22 | VCC2 | Power supply terminal |
| 9 | GND | Ground terminal | 23 | NC | Non connection |
| 10 | CR | Connection terminal of CR for setting chopping frequency | 24 | OUT2A | H bridge output terminal |
| 11※1 | TEST0 | NC Non connection Terminal for testing | 25 | RNF2S | Input terminal of current detection comparator |
| 12 | MTH | Current decay mode setting terminal | 26 | RNF2 | output current detection Connection terminal of resistor for |
| 13 | VREF | Output current value setting terminal | 27 | OUT2B | H bridge output terminal |
| 14 | PS | Power save terminal | 28 | NC | Non connection |
评估板上有多种元件,如步进电机驱动器IC1(BD63715AEFV等型号)、电容C0 - C8、电阻R0、R1等。其中,C0和R0用于设置斩波频率,C1和C2用于电源稳定等。部分元件未安装,如C3 - C8、R16、R17、R20、R21等,可根据需要进行安装。
需要主电源(VCC:28V以下的直流电源)、副电源(5V直流电源)、CLK信号振荡器(如微计算机或函数发生器)和步进电机。
将SW1(ENABLE端子)切换到“OPEN”,所有输出晶体管强制关闭(电机输出断开);切换到“Hi”(2.0V < Hi < 5.0V,0.8V > Lo)则使能。该端子通过IC内部100kΩ电阻下拉到GND,评估板配备5V/OPEN开关。当ENABLE = L时,CLK输入被阻断,内部转换器电路的相位推进操作停止,但在ENABLE = L期间切换励磁模式,当ENABLE复位为HI时,新的励磁模式将生效。
将SW7(PS端子)切换到“OPEN”,电路进入待机状态,电机输出断开。待机状态下,转换器电路复位,电角度初始化;切换到“Hi”(2.0V < Hi < 5.0V,0.8V > Lo)则使能。该端子通过IC内部100kΩ电阻下拉到GND,评估板配备5V/OPEN开关。从PS = OPEN切换到HI时,恢复到正常状态并使电机输出有效有最大40μs的延迟。
将SW5(CW_CCW端子)切换到“Hi”或“OPEN”,可设置电机旋转方向(2.0V < Hi < 5.0V,0.8V > Lo)。该端子通过IC内部100kΩ电阻下拉到GND,设置的变化在CLK上升沿立即生效。
通过切换SW2(MODE 0端子)和SW3(MODE 1端子)到“Hi”或“OPEN”,可设置电机励磁模式(2.0V < Hi < 5.0V,0.8V > Lo)。该端子通过IC内部100kΩ电阻下拉到GND。不同型号的驱动器在不同MODE0和MODE1组合下的励磁模式如下:
| MODE0 | MODE1 | BD63715AEFV | BD63725BEFV | BD63525AEFV | BD63511EFV | BD63521EFV |
| L | L | FULL A | FULL B | |||
| L | H | HALF A | HALF C | |||
| H | L | HALF B | Quarter | 1/8 | ||
| H | H | Quarter | 1/16 |
通过连接在CR端子和GND之间的电容(C0)和电阻(R0)设置输出频率。建议连接外部C0(470p - 1500pF)和R0(10k - 200kΩ),评估板连接的C0 = 1000pF,R0 = 39KΩ,斩波频率约为24.5kHz。若该端子开路或外部偏置,无法进行正常的PWM恒流控制,使用PWM恒流控制时,必须同时连接C和R元件。
| 可根据MTH端子的输入电压选择电流衰减模式(SLOW DECAY / MIX DECAY / FAST DECAY): | MTH terminal input voltage [V] | Current decay mode |
| 0.0 to 0.3 | SLOW DECAY | |
| 0.4 to 1.0 | MIX DECAY | |
| 1.5 to 3.5 | FAST DECAY |
评估板的输入电压可通过连接在5V - GND之间的电阻(R17,R16)进行5V分压设置,评估板未安装R16、R17,需在确认电机驱动时进行调整。当端子电压不稳定时,应在MTH端子 - GND之间连接电容C34。避免MTH端子开路,否则输入不稳定,PWM操作可能不稳定。若使用电阻分压输入,需考虑最大2μA的流出电流。
VREF端子用于设置输出电流值,输出电流最大值可通过VREF电压(R20,R21,C4)和电流检测电阻(RNF电阻,R1,R2,R7,R8)设置。评估板未安装R20、R21、C4,VREF端子输入电压可通过连接在5V - GND之间的电阻(R20,R21)进行5V分压设置。
不同型号和励磁模式下输出电流的设置公式如下:
避免VREF端子开路,否则输入电压不稳定,VREF电压升高,设定电流增大,可能导致大电流流动和故障。若VREF端子施加超过3V的电压,输出可能会有大电流流动,触发OCP或TSD保护。若使用电阻分压输入,需考虑最大2μA的流出电流。VREF电压可控制的最小电流由电机线圈的L、R值和PWM驱动的最小导通时间决定。
触发信号为CLK的上升沿,每次CLK输入,电角度推进一个单位(2.8V < Hi < 5.0V,0.6V < Lo)。该端子通过IC内部100kΩ电阻下拉到GND。
可根据驱动情况改变电源部分的电解电容(C1)和陶瓷电容(C2)的电容值,评估板连接的C1 = 100μF,C2 = 0.1μF。
连接到CR端子的外部电容(C0)和电阻(R0)在VCRH和VCRL电平之间反复充电和放电。从VCRL充电到VCRH期间,电流检测比较器的输出被屏蔽,此期间定义为最小导通时间。电压达到VCRH后,CR端子开始放电。在此期间,当输出电流达到电流限制时,IC进入衰减模式。CR继续放电直到达到VCRL,此时IC输出再次打开,电流输出和CR端子同时开始充电。CR充电时间(tONMIN)和放电时间(tDISCHARGE)由外部元件根据以下公式设置,tONMIN和tDISCHARGE之和即为斩波周期tCHOP: [t{ONMIN}[s] fallingdotseq C 0 cdot R' cdot R 0 /left(R'+R 0right) cdot ln [(VCR - 0.4) /(VCR - 1.0)]] [VCR = V cdot R 0 /left(R'+R 0right)] 其中,V为内部稳压器电压5V(典型值),R'为CR端子内部阻抗5kΩ(典型值)。 [t{DISCHARGE }[s] fallingdotseq C 0 cdot ln [(1+alpha) / 0.4]] α可参考相关图表。 [t{CHOP}[s] fallingdotseq t{ONMIN} + t_{DISCHARGE }]
建议在CR端子连接至少10kΩ的电阻(推荐10kΩ - 200kΩ),电容范围为470pF - 1500pF。使用数千pF以上的电容,噪声屏蔽期(tONMIN)会增加,输出电流可能因输出电机线圈的内部L和R组件而超过设定值。同时,应确保斩波周期(tCHOP)不要过长,否则会增加输出纹波,降低平均输出电流和输出旋转效率。需选择最佳值,以最小化电机驱动声音和输出电流波形的失真。
PWM恒流控制可选择电流衰减模式,包括快速衰减和慢速衰减的比例。不同衰减模式的优缺点如下:
评估板尺寸为80mm x 80mm x 1.6mm(4层),材料为FR - 4,铜箔厚度为35μm。
文档给出了在特定条件下(VCC = 24V,VREF = 0.5V,MTH = 0.5V,CR = 39kΩ/1000pF,RNF = 0.1
