在电子设备的设计中,显示模块是至关重要的组成部分。今天我们来详细探讨一下东莞市日月液晶显示科技有限公司生产的RY24049B0 - 00 TFT - LCD模块,了解它的各项特性、参数以及使用注意事项。
文件下载:104990542.pdf
RY24049B0 - 00是一款透射式非晶硅TFT - LCD模块,由TFT - LCD面板、驱动电路和背光单元组成。它的面板尺寸为2.4英寸,分辨率达到240x320,具备高图像质量和部分屏幕显示功能,还有睡眠和待机模式以实现节能。
| No | Item | Specification | Remark |
| 1 | Display Mode | High Resolution & Wide View | |
| 2 | Screen Size | 2.4inch (diagonal) | |
| 3 | Resolution | 240XRGBX320 | |
| 4 | Color Number | 262K TFT | |
| 5 | Color Arrangement | RGB - stripe | |
| 6 | Driver IC | ST7789V | |
| 7 | Back Light | White LED*6 | |
| 8 | Viewing Direction | ALL | |
| 9 | Interface | MCU8bit | |
| 10 | Surface Treatment | UV Cut | |
| 11 | touch panel | N/A |
该模块适用于手机和便携式多媒体设备等,在这些设备中能够提供清晰的显示效果。
| 模块的机械细节如图1所示,其外形尺寸、有效显示区域、分辨率、点尺寸和亮度值等参数如下: | Parameter | Specifications | Unit |
| Outline dimensions | 42.72 x60.26 x 2.45±0.1(D) (LCM,no include FPC) | mm | |
| Active area | 36.72(W) x48.96(H) | mm | |
| Resolution | 240XRGBX320 dots | - | |
| Dot size | 0.153x0.153 | mm | |
| Luminance value | 260 ( 60ma 时) | cd /㎡ |
| TFT - LCD模块的各项电气参数有明确的规定,例如模拟工作电压、逻辑工作电压、数字工作电压等。在设计电路时,需要严格按照这些参数进行供电,以确保模块正常工作。 | Item | Symbol | Unit | Condition | Min. | Typ. | Max. | Note |
| Power and Operation Voltage | ||||||||
| Analog Operating Voltage | VCI | V | Operating voltage | 2.5 | 2.8 | 3.3 | Note2 | |
| Logic Operating Voltage | VDDI | V | 1/O supply voltage | 1.65 | 2.8 | 3.3 | Note2 | |
| Digital Operating voltage | VCORE | V | Digital supply voltage | 1.5 | Note2 | |||
| Gate Driver High Voltage | VGH | V | 12.0 | 21.0 | Note3 | |||
| Gate Driver Low Voltage | VGL | V | -12.5 | -7.0 | Note3 | |||
| Driver Supply Voltage | V | [VGH - VGL] | 32 | Note3 | ||||
| Input and Output | ||||||||
| Logic High Level Input Voltage | VIH | V | 0.7*VDDI | VDDI | Note1,2,3 | |||
| Logic Low Level Input Voltage | VIL | V | VSS | 0.3*VDDI | Note1,2,3 | |||
| Logic High Level Output Voltage | VOH | V | IOL = -1.0mA | 0.8*VDDI | Note1,2,3 | |||
| Logic Low Level Output Voltage | VOL | V | IOL = 1.0mA | VSS | 0.2*VDDI | Note1,2,3 | ||
| Logic High Level Input Current | IH | uA | 1 | Note1,2,3 | ||||
| Logic Low Level input Current | IIL | uA | -1 | Note1,2,3 | ||||
| Logic Input Leakage Current | ILEA | uA | VIN = VDDI or VSS | -0.1 | Note1,2,3 |
| 背光单元的电流、正向电压、色度、亮度和均匀性等参数也有相应的要求。在设计背光电路时,要注意输入采用恒流而不是恒压,因为LED的发光强度强烈依赖于驱动电流。 | Item | Symbol | Min. | Typ. | Max. | Unit | Remark |
| Current | IF | 60 | 70 | 80 | mA | IF = 80mA IF = 3.2V | |
| Forward voltage | VF | 2.9 | 3.2 | 3.5 | V | ||
| Chroma | X | 0.250 | 0.30 | ||||
| Y | 0.250 | 0.30 | |||||
| Brightness | L | 4000 | Cd/m2 | ||||
| Uniformity | UBL | 80 | % |
| 该模块的接口规格明确,每个引脚都有其特定的功能。例如,LED - K和LEDA用于背光电源输入,CS是芯片选择输入引脚等。在连接电路时,要准确无误地连接各个引脚,避免出现错误。 | Pin No | Symbol | Description | Note |
| 1 | LED - K | Power supply Cathode input for backlight | ||
| 2 | LEDA | Power supply Anode input for backlight | ||
| 3 | GND | Ground | ||
| 4 | VCC | Power supply input for LCM:2.8V | ||
| 5 | IOVCC | Power supply input for LCM:1.8V | ||
| 6 | NC | NC | ||
| 7 | CS | Chip select input pin. | ||
| 8 | RESET | Reset signal input Pin | ||
| 9 | RS | Data/Instruction select input pin ---RS = ’H ’: Display data. ---RS = ’L ’: Instruction data. | ||
| 10 | WR | A write strobe signal can be input via this pin and initiallizes a write operation when the signal is low. | ||
| 11 | RD | A read strobe signal can be input via this pin and initiallizes a read operation when the signal is low. | ||
| 12~19 | DB7~DB0 | DATA | ||
| 20 | GND | Ground | ||
| 21~24 | NC | NC |
| 包括VSYNC/HSYNC的建立时间和保持时间、DE的建立时间和保持时间等参数,这些参数对于确保图像的正确显示至关重要。 | Item | Symbol | Unit | Min | Typ | Max |
| VSYNC/HSYNC setup time | tSYNCS | ns | 5 | |||
| VSYNC/HSYNC hold time | tSYNCH | ns | 5 | |||
| DE setup time | tENS | ns | 5 | |||
| DE hold time | tENH | ns | 5 | |||
| PCLK "Low" level pulse width | PWDL | ns | 10 | |||
| PCLK "High" level pulse width | PWDH | ns | 10 | |||
| PCLK cycle time | tCYCD | ns | 20 | |||
| Data setup time | tPDS | ns | 6 | |||
| Date hold time | tPDH | ns | 6 | |||
| PCLK, VSYNC, HSYNC, DE rise/fall time | trgbr,trgbf | ns | 13 |
| 输入和输出的高低电压、待机模式下的电流消耗等参数也有详细规定。在设计电路时,要根据这些参数来选择合适的电源和驱动电路。 | Item | Symbol | Unit | Test Condition | Min | Typ | Max | Notes |
| Input low voltage | V | IOVCC = 1.65~3.3 | 0.2*IOVCC | |||||
| Input high voltage | V1H | V | IOVCC = 1.65~3.3 | 0.8*IOVCC | ||||
| Output high voltage (1) | VOH1 | V | IOVCC = 1.65~3.3, IOH = 0.1mA | 0.8*IOVCC | (DB17 - 0,SDO) | |||
| Output low voltage(1) | Vou | V | IOVCC = 1.65~3.3, IOL = 0.1mA | 0.2*IOVCC | (DB17 - 0, SDO) | |||
| I/O leakage current | Iu | UA | Vin = 0~IOVCC | -1 | 1 | |||
| Current consumption during standby mode: (IOVCC - GND)+ IsT | uA | IOVCC = VCC = VCI = 2.8V, Ta = 25°C | 1.4 | 10 | (VCC - GND) |
| 包括串行时钟周期时间、串行时钟低电平脉冲宽度、串行输入输出数据的建立和保持时间等参数。这些参数对于数据的传输和处理有着重要的影响。 | Item | Symbol | Unit | Min | Typ | Max | |
| Serial clock cycle time | Write (received) | tSCYC | ns | 20 | |||
| Read (transmitted) | 100 | ||||||
| Serial clock "Low" level pulse width | Write (received) | tSCH | ns | 10 | |||
| Read (transmitted) | 50 | ||||||
| Serial clock rise/fall time | tscr, tscf | ns | 20 | ||||
| Chip select setup time | tCSU | ns | 20 | ||||
| Chip select hold time | ns | - | |||||
| Serial input data setup time | tSISU | ns | 5 | ||||
| Serial input data hold time | tsIH | ns | 10 | ||||
| Serial output data setup time | tSOD | ns | 80 | 150 | |||
| Serial output data hold time | tSOH | ns | 80 |
| 复位信号的低电平宽度和上升时间有明确要求,确保模块能够正确复位。 | Item | Symbol | Unit | Min | Max |
| Reset "Low" level width | tRES | ms | 1 | ||
| Reset rise time | trRES | US | 10 |
| 模块的光学规格包括响应时间、对比度、视角、色度、NTSC、串扰和透过率等参数。这些参数直接影响到显示效果,在选择和使用该模块时需要重点关注。 | Item | Symbol | Condition | Specification | Unit | Remark | ||
| Min. | Typ. | Max. | ||||||
| Response time (By Quick) | Tr + Tf | 0 = 0° | - | 30 | ms | Note 5 | ||
| Contrast ratio | CR | 0 = 0° | 250 | Note 2,6 | ||||
| Viewing angle | Top | CR = 10 | 45 | deg. | Note 2,6,7 | |||
| Bottom | CR = 10 | 20 | ||||||
| Left | CR = 10 | 45 | ||||||
| Right | CR≥10 | 45 | ||||||
| Color chromaticity (CF only with ITO, light source is C light, CIE 1931) | Wx | -0.02 | 0.308 | +0.02 | Note 3 | |||
| Wy | 0.325 | |||||||
| Rx | 0.612 | |||||||
| Ry | 0.329 | |||||||
| Gx | 0 = 0° | 0.299 | ||||||
| Gy | 0.567 | |||||||
| Bx | 0.144 | |||||||
| By | 0.110 | |||||||
| NTSC | 55 | Note 3 | ||||||
| Cross talk | Ct | 2 | % | Note 9 | ||||
| Transmittance | Trans | 5 | % | Note 4 |
| 模块的工作温度范围为 - 10℃到60℃,存储温度范围为 - 20℃到70℃,并且不能在腐蚀性气体环境中使用。同时,TFT - LCD的颜色会随环境温度略有变化,但这种现象是可逆的。 | Item | Symbol | Min | Max | Unit | Remark |
| Operation temperature range | Top | -10 | 60 | ℃ | Ambient | |
| Storage temperature range | Tst | -20 | 70 | ℃ | Ambient |
包括高温存储、低温存储、高温高湿存储、振动测试、静电放电测试、热冲击测试、高温操作、低温操作、高温高湿操作和FPC剥离强度测试等。通过这些测试可以确保模块在不同环境下的可靠性。
检验标准适用于TFI模块规格,在特定的检验条件下(日光灯下20 - 40W,产品距离检查员眼睛30cm,倾斜度30°),对亮点、暗点和线等缺陷有明确的检验标准和可接受数量。
模块的包装采用每托盘10片加1个盖子(EPE),放入包装袋,15个托盘加1个虚拟托盘共150片,放入防静电袋,再放入纸箱,并用EPE缓冲片保护。
在处理模块时,要避免施加强烈的机械应力,不要用硬物触碰显示表面,不要在显示表面放置重物,保持表面清洁,避免使用特定的清洁材料,防止静电损坏,不要直接用手触摸输出引脚,不要拆卸模块和触摸面板的FPC。
不要将模块长时间置于高温、高湿度环境,避免阳光直射和强紫外线照射,防止水分凝结,按照纸箱规定的数量堆叠。
在安装和拆卸模块时要关闭电源,防止电击,遵守驱动IC控制算法,注意背光电源极性,不超过绝对最大额定值,避免长时间显示静态图像,防止FPC弯曲过度,注意触摸屏的通风口和ITO膜的使用。
使用合适的缓冲垫,将缓冲垫放置在可视区域外,确保边框/外壳边缘位置正确,避免意外输入。
如果液晶泄漏,要远离眼睛和嘴巴,建议在显示表面贴上透明保护板,缓慢剥离偏光片上的保护膜以减少静电。
以上就是RY24049B0 - 00 TFT - LCD模块
