如何在Oracle数据库中找出损坏索引?
在Oracle数据库中如何找出损坏索引呢? 下面我们人为构造一个案例,将索引块损坏。如下案例所示:
SQL> create tablespace test_data
2  datafile  '/u01/app/oracle/oradata/gsp/test_data_01.dbf'
3  size 200M autoextend off
4  logging
5  segment space management auto
6  extent management local;
Tablespace created.
SQL> create tablespace test_index
2  datafile  '/u01/app/oracle/oradata/gsp/test_idx_01.dbf'
4  logging
Tablespace created.
SQL> create user kerry
2  identified by 123456
3  default tablespace test_data;
User created.
SQL> grant connect to kerry;
SQL> grant resource to kerry;
上述脚本是创建表空间,创建用户kerry并授权,然后使用kerry账号登录数据库,构造测试数据,在TEST表上创建索引IX_TEST
SQL> show user;
USER is "KERRY"
SQL>
SQL> CREATE TABLE TEST(ID  NUMBER(10), NAME VARCHAR2(64));
Table created.
SQL> DECLARE I  NUMBER;
2  BEGIN
3    FOR I IN 1..1000 LOOP
4      INSERT INTO TEST VALUES(I, LPAD('T', 60));
5     END LOOP;
6  COMMIT;
7  END;
8  /
PL/SQL procedure successfully completed.
SQL> CREATE INDEX IX_TEST ON KERRY.TEST(NAME) TABLESPACE TEST_INDEX;
Index created.
然后使用下面脚本找到索引段数据库文件ID,以及索引段的第一个块的块号。
SQL> show user;
USER is "SYS"
SQL> col segment_name for a32;
SQL> col header_file for 9999;
SQL> col header_block for 9999;
SQL> select segment_name
2   ,header_file
3   ,header_block
4   ,blocks
5  from dba_segments ds
6  where ds.owner='KERRY' and ds.segment_name='IX_TEST';
SEGMENT_NAME                     HEADER_FILE HEADER_BLOCK     BLOCKS
IX_TEST                                    8          130         16
SQL>
构造坏块的方法有不少(例如BBED等),这里我们使用RMAN下面的命令clear,可以标记数据块为corrupt,标记数据文件8中130号数据块为坏块。
[oracle@DB-Server ~]$ rman target /
Recovery Manager: Release 11.2.0.1.0 - Production on Thu Sep 13 17:41:05 2018
Copyright (c) 1982, 2009, Oracle and/or its affiliates.  All rights reserved.
connected to target database: GSP (DBID=644393201)
RMAN> recover datafile 8 block 130 clear;
Starting recover at 13-SEP-18
using target database control file instead of recovery catalog
allocated channel: ORA_DISK_1
channel ORA_DISK_1: SID=12 device type=DISK
Finished recover at 13-SEP-18
RMAN>
那么我们先来看看使用那些方法验证索引损坏了,测试验证一下看看是否可行。
1:使用ANALYZE分析验证索引结构
[oracle@DB-Server ~]$ sqlplus / as sysdba
SQL*Plus: Release 11.2.0.1.0 Production on Thu Sep 13 17:42:03 2018
Copyright (c) 1982, 2009, Oracle.  All rights reserved.
Connected to:
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
SQL> analyze index kerry.ix_test validate structure;
ERROR at line 1:
ORA-01578: ORACLE data block corrupted (file # 8, block # 130)
ORA-01110: data file 8: '/u01/app/oracle/oradata/gsp/test_idx_01.dbf'
如上截图所示,如果索引损坏(Corrupt Index),那么使用analyze index validate structure就会报错。要检查整个数据库所有的损坏索引(Corrupt Indexes)的话,就可以借助下面脚本:
spool analy_index.sql
SET PAGESIZE 50000;
SELECT
'ANALYZE INDEX  ' || OWNER || '.' || INDEX_NAME|| ' VALIDATE STRUCTURE;' FROM DBA_INDEXES;
spool off;
@analy_index.sql
2:使用系统视图v$database_block_corruption查看损坏索引
如下所示,我们使用这个脚本来查看出现坏块的索引,发现这个脚本无法找出坏块索引。
set pagesize 50 linesize 170
col segment_name format a30
col partition_name format a30
SELECT DISTINCT file#,
segment_name,
segment_type,
tablespace_name,
partition_name
FROM   dba_extents a,
v$database_block_corruption b
WHERE  a.file_id = b.file#
AND a.block_id <= b.block#
AND a.block_id + a.blocks >= b.block#;
原因分析如下,视图v$database_block_corruption中有坏块记录,但是我们将索引段的第一个块标记为坏块后,在dba_extents中没有该索引段的记录了。所以这种情况下的索引损坏,这个SQL语句根本无法找出坏块索引。
SQL> SELECT file_id,
2         segment_name,
3         segment_type
4  FROM   dba_extents
5  WHERE  file_id = 8 ;
no rows selected
2         segment_name,
3         segment_type
4 FROM   dba_extents
5  WHERE  owner = 'KERRY';
FILE_ID SEGMENT_NAME                     SEGMENT_TYPE
7 TEST                             TABLE
7 TEST                             TABLE
SQL>
因为一个段的第一个区的第一个块是FIRST LEVEL BITMAP BLOCK,第二个块是SECOND LEVEL BITMAP BLOCK,这两个块是用来管理free block的,第三个块是PAGETABLE SEGMENT HEADER,这个块才是segment里的HEADER_BLOCK,再后面的块就是用来记录数据的。关于这些知识,可以参考我博客ORACLE关于段的HEADER_BLOCK的一点浅析。而我们最上面的例子,是将第一个块构造为坏块,所以导致上面SQL无法查出。 我们重新构造案例,如我们将索引段的数据块构造为坏块,例如下面,将块号148人为构造坏块。那么此时这个脚本就能找出坏块索引了。所以综上述实验可以看出,这个脚本查找坏块索引是有条件的,要看索引段损坏的块是什么类型
SQL> SELECT FILE_ID,
2         BLOCK_ID,
3         BLOCKS
FROM   DBA_EXTENTS
4    5  WHERE  OWNER ='&OWNER'
6       AND SEGMENT_NAME = '&TABLE_NAME';
Enter value for owner: KERRY
old   5: WHERE  OWNER ='&OWNER'
new   5: WHERE  OWNER ='KERRY'
Enter value for table_name: IX_TEST
old   6:      AND SEGMENT_NAME = '&TABLE_NAME'
new   6:      AND SEGMENT_NAME = 'IX_TEST'
FILE_ID   BLOCK_ID     BLOCKS
8        144          8
8        152          8
SQL> SELECT HEADER_FILE
2       , HEADER_BLOCK
3       , BYTES
4       , BLOCKS
5       , EXTENTS
FROM DBA_SEGMENTS
6    7  WHERE OWNER='&OWNER' AND SEGMENT_NAME='&SEGMENT_NAME';
Enter value for segment_name: IX_TEST
old   7: WHERE OWNER='&OWNER' AND SEGMENT_NAME='&SEGMENT_NAME'
new   7: WHERE OWNER='KERRY' AND SEGMENT_NAME='IX_TEST'
HEADER_FILE HEADER_BLOCK      BYTES     BLOCKS    EXTENTS
8    146   131072   16   2
SQL>
RMAN> recover datafile 8 block 148 clear;
