基于LM20的±1.5°C 模拟输出温度传感器
今日头条
1151人已加入
  The LM20 is a precision analog output CMOS integrated-circuit temperature sensor that operates over −55°C to 130°C. The power supply operating range is 2.4 V to 5.5 V. The transfer function of LM20 is predominately linear, yet has a slight predictable parabolic curvature. The accuracy of the LM20 when specified to a parabolic transfer function is ±1.5°C at an ambient temperature of 30°C. The temperature error increases linearly and reaches a maximum of ±2.5°C at the temperature range extremes. The temperature range is affected by the power supply voltage. At a power supply voltage of 2.7 V to 5.5 V, the temperature range extremes are 130°C and −55°C. Decreasing the power supply voltage to 2.4 V changes the negative extreme to −30°C, while the positive extreme remains at 130°C.
  The LM20 quiescent current is less than 10 μA. Therefore, self-heating is less than 0.02°C in still air. Shutdown capability for the LM20 is intrinsic because its inherent low power consumption allows it to be powered directly from the output of many logic gates or does not necessitate shutdown.
  特性
  Rated for −55°C to 130°C Range
  Available in SC70 and DSBGA Package
  Predictable Curvature Error
  Suitable for Remote Applications
  Accuracy at 30°C ±1.5 to ±4°C (Maximum)
  Accuracy at 130°C and −55°C ±2.5 to ±5°C (Maximum)
  Power Supply Voltage Range 2.4 V to 5.5 V
  Current Drain 10 μA (Maximum)
  Nonlinearity ±0.4% (Typical)
  Output Impedance 160 Ω (Maximum)
  Load Regulation
     0 μA < IL< 16 μA −2.5 mV (Maximum)
  2 Applications
  Cellular Phones
  Computers
  Power Supply Modules
  Battery Management
  FAX Machines
  Printers
  HVAC
  Disk Drives
  Appliances
PART NUMBER
PACKAGE
BODY SIZE (NOM)
LM20
SC70 (5)
2.00 mm × 1.25 mm
DSBGA (4)
0.96 mm × 0.96 mm
  该产品品牌下其它产品相关信息可咨询:https://www.iczoom.com/brand/509-c-1-20.html
  • 相关推荐
