在电子设计的广阔领域中,功率晶体管作为关键元件,对电路的性能和稳定性起着至关重要的作用。今天,我们将深入探讨 onsemi 公司推出的 NJW44H11G 80V、10A 功率晶体管,了解它的特点、性能参数以及适用的应用场景。
文件下载:NJW44H11-D.PDF
NJW44H11G 是一款采用塑料封装的硅 NPN 功率晶体管,其 TO - 3P 塑料外壳(340AB)设计,适用于多种通用功率放大和开关应用。它可作为开关稳压器、转换器和功率放大器等应用中的输出或驱动级,为各类电路提供可靠的功率支持。
| 在 (T_{A}=25^{circ} C) 的条件下,该晶体管的各项最大额定值如下: | Symbol | Rating | Max | Unit |
| (V_{CEO}) | Collector - Emitter Voltage | 80 | Vdc | |
| (V_{EBO}) | Emitter - Base Voltage | 5.0 | Vdc | |
| (I_{C}) | Collector Current - Continuous | 10 | A | |
| (I_{CM}) | Collector Current - Peak (Note 1) | 20 | A | |
| (P_{D}) | Total Power Dissipation @ (T_{C} = 25^{circ} C) | 120 | Watts |
需要注意的是,当应力超过最大额定值表中列出的数值时,可能会损坏器件,影响其功能和可靠性。这里的峰值电流测试条件为脉冲宽度 (5ms),占空比 ≤ 10%。
| 在 (T_{A}=25^{circ} C) 条件下,晶体管的电气特性涵盖了关断、导通、动态和开关时间等方面。 | Symbol | Characteristic | Min | Typ | Max | Unit |
| OFF CHARACTERISTICS | ||||||
| (V_{CEO}) | Collector - Emitter Sustaining Voltage ((I{C} = 30 mAdc), (I{B} = 0)) | 80 | Vdc | |||
| (I_{CES}) | Collector - Cutoff Current ((V{CE}=Rated V{CEO}), (V_{BE}=0)) | |||||
| (I_{EBO}) | Emitter Cutoff Current ((V_{BE} = 5.0 Vdc)) | uAdc | ||||
| ON CHARACTERISTICS | ||||||
| (h_{FE}) | DC Current Gain ((I{C} = 2 A), (V{CE} = 2 V)) | 100 | 400 | |||
| DC Current Gain ((I{C} = 4 A), (V{CE} = 2 V)) | 80 | 320 | ||||
| (V_{CE(sat)}) | Collector - Emitter Saturation Voltage ((I{C} = 8 A), (I{B} = 400 mA)) | 1.0 | V | |||
| (V_{BE(on)}) | Base - Emitter Turn - on Voltage ((I{C} = 8 A), (V{CE} = 2.0 V)) | 1.5 | V | |||
| DYNAMIC CHARACTERISTICS | ||||||
| (C_{obo}) | Output Capacitance ((V_{CB} = 10 V), (f = 1.0 MHz)) | 65 | pF | |||
| (f_{T}) | Cutoff Frequency ((I{C} = 500 mA), (V{CE} = 5 V), (f = 1.0 MHz)) | 85 | MHz | |||
| SWITCHING TIMES | ||||||
| (t{d} + t{r}) | Delay and Rise Times ((I{C} = 5.0 Adc), (I{B1} = 0.5 A)) | 300 | ns | |||
| (t_{s}) | Storage Time ((I{C} = 5.0 Adc), (I{B1} = I_{B2} = 0.5 A)) | 500 | ns | |||
| (t_{f}) | Fall Time ((I{C} = 5.0 Adc), (I{B1} = I_{B2} = 0.5 A)) | 140 | ns |
这些参数为工程师在设计电路时提供了重要的参考依据,不同的应用场景需要根据具体需求对这些参数进行合理选择和优化。
文档中还给出了一系列典型特性曲线,包括直流电流增益、集电极 - 发射极饱和电压、基极 - 发射极饱和电压、输出电容、电流增益带宽积、功率温度降额以及安全工作区等。这些曲线直观地展示了晶体管在不同工作条件下的性能表现,有助于工程师更深入地了解器件的特性,从而进行更精准的电路设计。
虽然在文库搜索关于“onsemi NJW44H11G典型特性曲线的应用”的内容时遇到了网络问题未能成功获取,但我们可以推测这些典型特性曲线在实际设计中的重要作用。例如,直流电流增益曲线可以帮助工程师确定在不同集电极电流下晶体管的放大能力,从而选择合适的工作点;功率温度降额曲线则能指导工程师在不同温度环境下合理使用晶体管,避免因过热导致器件损坏。大家在实际设计中,不妨仔细研究这些曲线,思考如何根据它们来优化电路性能。
NJW44H11G 主要适用于高端消费音频产品,如家庭放大器和家庭接收器等。在这些应用中,其高功率可靠性、精确信号再现和高放大器带宽等特性能够充分发挥作用,为用户带来高品质的音频体验。
该晶体管采用 TO - 3P(无铅)封装,每导轨包装 30 个单元。其机械外壳尺寸有详细的规定,各项尺寸的最小、标称和最大值都有明确标注,这为电路板的设计和布局提供了精确的参考。同时,文档中还给出了通用标记图,不过需要注意的是,实际的零件标记应以器件数据手册为准。
onsemi 的 NJW44H11G 功率晶体管凭借其丰富的特性、出色的性能参数和广泛的应用场景,成为电子工程师在设计功率放大和开关电路时的理想选择。在使用该器件时,工程师需要充分了解其各项参数和特性,结合具体的应用需求进行合理设计,以确保电路的性能和可靠性。大家在实际应用中是否遇到过类似晶体管的选型和设计问题呢?欢迎在评论区分享你的经验和见解。
