压力开关接线图
1.3w人已加入
  压力开关接线图
压力开关
  ①:公共触点。
  ①-③:压力上升时接通。
  ①-⑤压力下降时接通。
  M:手动复位。
  压力开关四根线的话,一般来说是一对常开点和一对常闭点。只能起泵不停泵,说明压力开关没有动作,理论上是由于动作值设得太高,需要调低。另外,如果管道没有封闭的话,压力也是上不去的,要测试其动作,须关闭所有的阀门。如图所示:
  压力开关接线如图,压力开关触点不可以直接驱动负载,需要加中间继电器进行触点隔离。三个触点,上限、下限、公共点。设定多大的压力,就对应的地方有线控制。很简单的,或者有的表有2跟线,然后需要手动调压力表。
  SMC压力开关是一种简单的压力控制装置, 当被测压力达到额定值时 ,压力开关可发出警报或控制信号。SMC压力开关接线方法如图所示:
压力开关
评论(0)
发评论
h1654156022.1315 2022-08-23
0 回复 举报
http://house.china.com.cn/sousou/%25C6%25BD%25CC%25A8%25B5%25D8%25D6%25B7%252C%2B%25D3%25F1%25BA%25CD%25D3%25E9%25C0%25D6B2024.cN_1s.htm http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%25BF%25CD%25B7%25FE%252C%2B%25B9%25FB%25B8%25D2%25D0%25C2%25B0%25D9%25C0%25FB%25D4%25DA%25CF%25DF%25D3%25E9%25C0%25D6B2024.cN%252C%25B1%25A6%25BC%25A6%25BD%25BB%25CD%25A8_2s.htm http://house.china.com.cn/sousou/%25C3%25E5%25B5%25E9%252C%2B%25C3%25E5%25B5%25E9%25D3%25C0%25B2%25FD%25D3%25E9%25C0%25D6B2024.cN_1s.htm http://house.china.com.cn/sousou/%25C1%25AA%25CF%25B5%25B7%25BD%25CA%25BD%252C%2B%25D0%25C2%25B0%25D9%25C0%25FB%25C3%25E5%25B5%25E9%25D3%25E9%25C0%25D6%25BB%25B9%25C4%25DC%25B2%25BB%25C4%25DC%25CD%25E6B2024.cN%252C%25D0%25C5%25D1%25F4%25BD%25B9%25B5%25E3_2s.htm http://house.china.com.cn/sousou/%25B4%25FA%25C0%25ED%252C%2B%25C3%25E5%25B5%25E9%25B0%25EB%25C9%25BD%25B9%25FA%25BC%25CA%25B6%25B7%25C5%25A3B2024.cN%252C%25D6%25CE%25D6%25DD%25D5%25D0%25C6%25B8_2s.htm 收起回复
