基于STM32单片机的USB时钟配置设计
控制/MCU
1920人已加入
1.首先要配置好系统的时钟如下:
RCC_DeInit();//将外设RCC寄存器重设为缺省值
/*EnableHSE*/
RCC_HSEConfig(RCC_HSE_ON);//设置外部高速晶振(HSE)
/*WaittillHSEisready*/
HSEStartUpStatus=RCC_WaitForHSEStartUp();//等待HSE起振,等待外部的时钟起振
if(HSEStartUpStatus==SUCCESS)
/*EnablePrefetchBuffer*/
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//使能或者失能预取指缓存
/*Flash2waitstate*/
FLASH_SetLatency(FLASH_Latency_2);//设置代码延时值
/*HCLK=SYSCLK*/
RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置AHB时钟(HCLK)
/*PCLK2=HCLK*/
RCC_PCLK2Config(RCC_HCLK_Div1);//设置高速AHB时钟(PCLK2)toAPB2
/*PCLK1=HCLK/2*/
//STM32的时钟比较复杂
RCC_PCLK1Config(RCC_HCLK_Div2);//设置高速AHB时钟(PCLK1)toAPB1
/*ADCCLK=PCLK2/8*/
RCC_ADCCLKConfig(RCC_PCLK2_Div8);//设置ADC时钟(ADCCLK)
/*PLLCLK=8MHz*9=72MHz*/
//设置外部时钟源,且PLL等于外部时钟频率*9
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
//此时PLLCLK=72MHz,这个得知道他的值,因为USB的时钟USBCLK=PLLCLK/1或者PLLCLK/1.5,但得确保USBCLK=48MHz
//所以配置USBCLK的时候选择是1.5分频
RCC_PLLCmd(ENABLE);//最后才激活PLL,必须最后才激活!
/*WaittillPLLisready*/
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//配置SYSCLK
/*WaittillPLLisusedassystemclocksource*/
while(RCC_GetSYSCLKSource()!=0x08)
else
/*IfHSEfailstostart-up,theapplicationwillhavewrongclockconfiguration.
Usercanaddheresomecodetodealwiththiserror*/
/*Gotoinfiniteloop*/
while(1)
voidUSBclock_Config()
RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//1.5分频
/*EnabletheUSBclock*/
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB,ENABLE);//此处是激活USB外设,USB属于APB1外设
