从固件入手讲解物联网设备
移动通信
314人已加入
固件   物联网
前言
近几年,物联网设备已渗透到生活的方方面面,为人们带来了极大的方便。但是,因其承载有人们日常生活产生的数据和隐私信息,其安全性也越来越受到人们的关注。在上一篇中,我们讨论了用脚本控制小米设备,这主要是从流量层面入手来进行的安全分析;在这一篇,主要从固件入手,分析固件的脆弱性。
开篇
“工欲善其事,必先利其器”,在正式开始,先来讲讲固件分析环境的搭建,主要就是binwalk的安装。由于固件压缩打包的方式有很多种,单用apt instll binwalk这条命令安装,很多文件系统的格式是不支持解压的,需要将各种解压插件一并安装,才能正确解压出固件中的文件系统。完整安装可参考binwalk的 官方安装文档 。但每次都要这样手动安装,笔者觉得很麻烦,因此写了安装脚本自动完成安装。
同时,考虑到有很多依赖包需要安装,Ubuntu系统带的apt源下载贼慢,可将其更换成阿里云的源,主要参考 这篇文章 。但每次照着帖子操作,相当浪费时间,也写了一个脚本自动换源的脚本,如下所示。
#!/bin/bash
# [*]change ubuntu system sources to aliyun source
#:< sudo mv /etc/apt/sources.list /etc/apt/sources.list.bak.1
codename=`lsb_release -c | cut -c 11-`
echo "codename is $codename"
sudo touch /etc/apt/sources.list
sudo echo "deb $codename main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb-src $codename main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb $codename-security main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb-src $codename-security main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb $codename-updates main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb-src $codename-updates main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb $codename-backports main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb-src $codename-backports main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb $codename-proposed main restricted universe multiverse" >> /etc/apt/sources.list
sudo echo "deb-src $codename-proposed main restricted universe multiverse" >> /etc/apt/sources.list
sudo apt-get update
#BLOCK
# [*]change pip sources to aliyun source
if [ ! -d ~/.pip ];then
    mkdir ~/.pip
fi
if [ -f ~/.pip/pip.conf ];
then
    sudo mv ~/.pip/pip.conf ~/.pip/pip.conf.bak
    sudo touch ~/.pip/pip.conf
else
fi
sudo echo "[global]" >> ~/.pip/pip.conf
sudo echo "index-url = https://mirrors.aliyun.com/pypi/simple" >> ~/.pip/pip.conf
在脚本中,主要分为两部分,先是将Ubuntu系统的源换成阿里云的源,并按照Ubuntu系统codename的不同,形成有针对性的apt源文件;再将pip的源也换成的阿里云的源。换源后,安装速度快了几十倍。
接着,就是对binwalk完整版的安装了,binwalk的安装文件和它的相关插件,我已从github上下载完成(在后文的工具中,已集成),如下图所示。
安装脚本为: install_binwalk.sh,如下所示,即是按照官方的安装方案编写的脚本(官方虽然有./deps.sh自动安装脚本,安装很慢,表示不太好用),该脚本目前只适用于Python2.7。
#!/bin/bash
#dependencies
sudo apt -y install python-lzma python-crypto
sudo apt -y install libqt4-opengl python-opengl python-qt4 python-qt4-gl python-numpy python-scipy python-pip
sudo pip install pyqtgraph
sudo pip install capstone
# Install standard extraction utilities(必选)
sudo apt -y install mtd-utils gzip bzip2 tar arj lhasa p7zip p7zip-full cabextract cramfsswap squashfs-tools sleuthkit default-jdk lzop srecord
#Install binwalk
#sudo apt-get install binwalk
cd binwalk
sudo python setup.py install
cd ..
# Install sasquatch to extract non-standard SquashFS images(必选)
sudo apt -y install zlib1g-dev liblzma-dev liblzo2-dev
cd sasquatch && sudo ./build.sh
cd ..
# Install jefferson to extract JFFS2 file systems(可选)
sudo pip install cstruct
cd jefferson && sudo python setup.py install
cd ..
# Install ubi_reader to extract UBIFS file systems(可选)
sudo apt -y install liblzo2-dev python-lzo
cd ubi_reader && sudo python setup.py install
cd ..
# Install yaffshiv to extract YAFFS file systems(可选)
cd yaffshiv && sudo python setup.py install
cd ..
#install unstuff (closed source) to extract StuffIt archive files
sudo cp stuff/bin/unstuff /usr/local/bin/
运行该脚本,待binwalk安装好后,大部分的固件都能解压了。这里以dlink dir-300为例,已在binwalk安装包中给出,在命令行中运行: binwalk -Me DIR-300_REVA_FIRMWARE_1.06B05_WW.zip
这是解压过程,其中,识别到squashfs文件系统,并解压出来。
系统文件目录如上图所示,已经解压出来了,下一步,即是对其中的文件进行分析了。
正文
1. 远程登录口令分析
很早之前,笔者就在想,很多固件都爆出了看似简单但危害又很大的安全隐患,如弱口令登录、web漏洞等,如果有一个脚本能自动地发现这些简单的安全隐患,那,真是一门省时的生意。不过,我能想到的东西,别人早实现了,见项目 firmwalk 。运行十分简单,在系统当前路径下,运行:
firmwalk.sh firmware_file_system_path
后跟固件中文件系统的路径即可,以dlinkdir-300为例,有如下结果。
这是脚本运行后的部分截图,可以看到,其中含包含admin,root,password等关键字的文件已列出,这些文件中,都有可能藏有口令信息。那我们就尝试着找一找这些文件中,是否包含口令信息,比如telnet、ftp、ssh、web等,都可能存在将口令硬编码到文件的情况。由上图所示,发现了telnet关键字,且在/etc/scripts/system.sh文件中出现,这个文件是随系统启动的脚本文件,那说明telnet服务是随系统启动了的,顺着这个线头捋应该有戏。打开这个文件,果然发现telnet的启动脚本,如下图所示。
跟到这个文件中再看一眼,用vim看下这个文件,如下所示:
红色框标注的即是telnet的启动命令,嘿,-u就像是跟的用户名和密码,用户名为:Alphanetworks,密码是一个变量,这个变量是cat /etc/config/image_sign的值,看下这个值是多少,如下图所示。
密码就是:wrgg19_c_dlwbr_dir300,按图索骥很容易就找到了。那为什么-u后就一定确定是用户名和密码,可以到telnetd中看一看,用vim打开该二进制文件,搜索password,如下图所示,-u选项后的参数就一目了然了,即是用户名和密码。
图中已经给出了telnetd的用法,同时在网上搜这个固件的telnet密码,也是文中这个口令,说明已经找正确。
另外,在其他一些固件中,会存在/etc/passwd或/etc/passwd.bak的文件,可用john命令进行密码破解,如下图所示。
解出来,口令是admin:1234。
2. 简单web的web漏洞发现与利用
大部分固件都支持web访问,而在提取出的固件文件中,可直接查看到固件的网页源码。那么是否有工具能通过源码审计的方式发现一些简单的漏洞,当然是有的,这里将一个简单的PHP代码审计工具RIPS。它使用了静态分析技术,能够自动化地挖掘PHP源代码中潜在的安全漏洞。先来看看它的安装,由于这款工具也是由PHP语言编写,首先需要搭建PHP和web服务运行环境。安装以下程序:
sudo apt install apache2 php7.2 libapache2-mod-php7.2
sudo /etc/init.d/apache2 restart
下载RIPS,下载地址为 见这里 ;下载完成后将其解压并放到/var/www/html/目录下,如下图所示。
再在浏览器中访问该路径即可:127.0.0.1/rips。
在path/file这一栏填写待分析的网页源码,将固件网页源码的路径填入,点击scan就能看到结果了,如下如所示。
扫了320个文件,Nothing vulnerable found,啥也没发现~~。不过木事,算是简单的验证了下RIPS的本事,因为网上已爆出了dlink dir-300系列的一些漏洞。比如这个信息泄露漏洞,漏洞出现在suashfs-root/www/model/__show_info.php文件中,如下图所示。
这里看到已经禁止了$REQUIRE_FILE的参数为var/etc/httpasswd和var/etc/hnapasswd。这么一看无法获取账号密码。但是我们可以从根路径开始配置httpasswd的路径,就可以绕过这个过滤了。Payload:
localhost/model/__show_info.php?REQUIRE_FILE=http://www.eefocus.com/var/etc/httpasswd
这里设置REQUIRE_FILE=http://www.eefocus.com/var/etc/httpasswd 成功绕过上面的 if判断,进行任意文件读取。这类漏洞看来还是得配合人工审计进行发现。那现在问题来了,已经找到的弱点,如何进行验证呢。
固件模拟
固件模拟的环境,笔者搭过,当时觉得很烦杂,本打算着写脚本来自动实现。不过,这也有人实现了,并打包成了虚拟机,可直接使用。 AttifyOS ,了解一下,国外大牛打包的。下载后,在tools/firmadyne中,运行程序,模拟dlink dir-300固件运行,命令为:
python fat.py ./DIR-300_REVA_FIRMWARE_1.06B05_WW.zip
如上图所示,当模拟出网卡,代表固件模拟成功。我们就可以试一下是否存在上面发现的脆弱点。先来看看web漏洞,在浏览器中运行:
192.168.0.1/model/__show_info.php?REQUIRE_FILE=http://www.eefocus.com/var/etc/httpasswd
如上图所示,口令已经找到,用户名为admin,密码为空。以得到的口令尝试登陆,顺利进入到web系统,如下图所示。
那么,再来看看,telnet的口令是否能成功。先用nmap扫描,看是否开启了telnet服务,如下图所示。
如上图所示,23端口已经打开,表明telnet服务随系统开启了,那么尝试telnet登录,如下图所示。
telnet给出了链接信息,感觉已经连上,但是没要求输入口令,执行命令也未回显。telnet服务似乎存在问题,想要进一步验证,可以下dir-300其他版本的固件,也可以买一个设备回来测。不过,虽然没有成功,但整个过程已清楚。下面给出整个过程用到的工具,本文的安装环境搭建和使用到的工具,见如下链接:
https://github.com/scu-igroup/firmware_analysis
github上工具文件结构:
change_sources.sh……….….更换Ubuntu系统源和pip源脚本
Install_full_binwalk……………安装完整版binwalk
firmwalk………………….....….固件分析工具
rips……………………………...PHP源码审计工具
总结
到此,固件安全分析的内容已讲完,看似内容比较简单,但对于刚入门来说,已经有相当的工作量了。光是分析环境搭建这一关,若对Linux不熟,都得费一些功夫。不过,耐心地一步一步来,总会有所得。本文,写了多个脚本程序,辅助大家搭建分析环境,同时,使用了多个工具来辅助进行固件脆弱点发现,也讲解了如何使用固件模拟的方式来验证脆弱点。对于高级的漏洞发现,那就靠自己不断地学习与分析了。在此,本文仅作抛砖引玉,欢迎大家一起讨论,并推荐一些好的固件分析方法,方便大家一起学习。
  • 相关推荐
  • 热点推荐
