高压增益稳定精密运算放大器
  ADI公司的ADHV4702-1是高压(220V)一增益稳定精密运算放大器,具有高输入阻抗和低输入偏压电流,低输入失调电压,低漂移和低噪音,对称工作电压±110 V,不对称单源工作电压220V,开环增益(AOL)170dB,共模抑制比(CMRR)160dB,最大事端失调电压(VOS) 2 μV/℃,输入噪音8 nV/√Hz ,主要用在高边电流检测,自动测试设备,高压驱动器,压电传感器以及数模转换器(DAC)输出缓冲器。本文介绍了ADHV4702-1主要特性,功能框图以及评估板EVAL-ADHV4702-1CPZ主要特性,电路图和材料清单。
  The ADHV4702-1 is a high voltage (220 V), unity-gain stable precision operational amplifier. The ADHV4702-1 offers high input impedance with low input bias current, low input offset voltage, low drift, and low noise for precision demanding applications. The next generation of proprietary semiconductor processes and innovative architecture from Analog Devices, Inc., enable this precision operational amplifier to operate from symmetrical dual supplies of ±110 V, asymmetrical dual supplies, or a single supply of 220 V.
  For precision performance, the ADHV4702-1 has a 170 dB typical open-loop gain (AOL) and a 160 dB typical common-mode rejection ratio (CMRR), as shown in Figure 2. The ADHV4702-1 also has a 2 μV/℃ maximum input offset voltage (VOS) drift and an 8 nV/√Hz input voltage noise.
  The exceptional dc precision of the ADHV4702-1 is complemented by excellent dynamic performance with a small signal bandwidth of 10 MHz and a slew rate of 74 V/μs. The ADHV4702-1 has an output current of 20 mA typical.
  The ADHV4702-1 offers high voltage input common-mode swing as well as high voltage output swing, enabling precision high voltage use cases such as high-side current sensing. The ADHV4702-1 is also ideally suited for forcing a voltage in precision bias and control applications.
  The ADHV4702-1 is available in a 12-lead, 7 mm × 7 mm lead frame chip scale package (LFCSP) with an exposed pad (EPAD) compliant to international electrotechnical commission (IEC) 61010-1 creepage and clearance standards. The copper EPAD provides a low thermal resistance path to improve heat dissipation and features high voltage isolation, allowing it to be safely connected to a 0 V ground plane regardless of VCC or VEE voltages. The ADHV4702-1 operates over the −40℃ to +85℃ industrial temperature range.
  ADHV4702-1主要特性:
  Wide range of operating voltages
  Dual-supply: ±12 V to ±110 V
  Asymmetrical supply operation: 24 V to 220 V
  Wide input common-mode voltage range: 3 V from rails
  High common-mode rejection ratio: 160 dB typical
  High AOL: 170 dB typical
  High slew rate
  74 V/μs typical
  24 V/μs typical with external input clamping diodes
  Low input bias current: 2 pA maximum
  Low input offset voltage: 1 mV maximum
  Low input offset voltage drift: 2 μV/℃ maximum
  Low input voltage noise: 8 nV/√Hz typical at 10 kHz
  Wide small signal bandwidth: 10 MHz typical
  Resistor adjustable quiescent current: 0.6 mA to 3 mA (VS = ±110 V)
  Unity-gain stable
  Thermal monitoring
  Small footprint: 12-lead, 7 mm × 7 mm LFCSP compliant with IEC 61010-1 spacing
  Shutdown mode
  ADHV4702-1应用:
  High-side current sensing
  Automated test equipment
  High voltage drivers
  Piezotransducers
  Digital-to-analog converter (DAC) output buffers
  Light detecting and ranging (LiDAR), avalanche photodiode (APD), single photon avalanche diode (SPAD) biasing
运算放大器
  图1.ADHV4702-1功能框图
  This user guide describes the EVAL-ADHV4702-1CPZ evalua-tion board, which helps users evaluate the ADHV4702-1 offered in a 7 mm × 7 mm, 12-lead lead frame chip scale package (LFCSP) with an exposed pad at the bottom. The evaluation board provides a platform for quick and easy evaluation of the ADHV4702-1. Figure 1 shows the top side of the evaluation board. Figure 2 shows the bottom side of the board with the large exposed copper area for attaching a heat sink to provide additional thermal management.
  The evaluation board is a 6-layer board designed to minimize leakage currents with its guard ring feature. It accepts Subminia-ture Version A (SMA) and Subminiature Version B (SMB) edge mounted connectors on the inputs for easy connection to test equipment or other circuitry.
  The ADHV4702-1 data sheet covers the specifications and details of the device operation and application circuit configurations and guidance. Full specifications of the ADHV4702-1 can be found in the ADHV4702-1 data sheet, available from Analog Devices, Inc., and must be consulted in conjunction with this user guide, especially when powering up the evaluation board for the first time.
  For safety, the EVAL-ADHV4702-1CPZ evaluation board is covered top and bottom with acrylic plastic guards to reduce the risk of inadvertent contact with high voltage. Do not operate the board without these guards in place. If the guards must be removed to adjust jumpers or change component values, discon-nect the board from the power supply before removing guards, and replace the guards before powering up again. For full precautions when using this high voltage evaluation board, see the High Voltage Evaluation Board section.
  评估板EVAL-ADHV4702-1CPZ主要特性:
  Full featured evaluation board for the ADHV4702-1
  Single-supply or dual-supply operation
  On-board power management circuit generates high voltage
  Edge mounted SMA and SMB connector provisions
  Easy connection to test equipment and other circuits
  Robust thermal management
  评估板EVAL-ADHV4702-1CPZ包括:
  图2.评估板EVAL-ADHV4702-1CPZ外形图(正面)
  图3.评估板EVAL-ADHV4702-1CPZ外形图(背面)
运算放大器
  图4.评估板EVAL-ADHV4702-1CPZ电路图(1)
运算放大器
  图5.评估板EVAL-ADHV4702-1CPZ电路图(2)
  评估板EVAL-ADHV4702-1CPZ材料清单:
运算放大器
运算放大器
  详情请见:
  https://www.analog.com/media/en/technical-documentation/data-sheets/ADHV4702-1.pdf
  和https://www.analog.com/media/en/technical-documentation/user-guides/EVAL-ADHV4702-1CPZ-UG-1444.pdf
  ADHV4702-1.pdf
