ST公司的PWD5F60是先进的电源片上系统,集成了栅极驱动器和双路半桥配置的四个N沟功率MOSFET,其RDS(ON)=1.38Ω,BVDSS=600V;驱动器工作电压10V-20V,负载电流高达1A,主要用在工业风扇和泵,烹饪罩和气体加热器,吹风机,工业驱动和工厂自动化以及电源单元。本文介绍了PWD5F60主要特性,框图和应用框图,以及评估板EVALPWD5F60主要特性和指标,电路图,材料清单和PCB设计图。
High density power driver - high voltage full bridge with integrated comparators
The PWD5F60 is an advanced power system-in package integrating gate drivers and four N-channel power MOSFETs in dual half-bridge configuration.
The PWD5F60 is an advanced power system-in-package integrating gate drivers and four N-channel power MOSFETs in a compact QFN package.
The integrated power MOSFETs have an RDS(ON) of 1.38 Ω and 600 V drain-source breakdown voltage. The embedded gate drivers feature two comparators that can be used for peak current control or overcurrent protection and integrate bootstrap diodes. This allows to effectively drive loads in a tiny space and to drastically reduce external components and bill of materials.
The EVALPWD5F60 demonstrates how to use the PWD5F60 to drive a single-phase load in full-bridge topology. This allows control of both the direction and the value of the current flowing into the load. Typical applications that can benefit from the high integration of the PWD5F60 are, for example, single-phase BLDC motors and fans.
The board has a very small footprint and an optimized layout thanks to the integrated features of the PWD5F60, and it can be simply run by applying the supply voltages and a direction signal.
The board allows easy selection and modification of the relevant external component values, enabling fast performance evaluation under different applicative conditions as well as fine tuning of final application components.
PWD5F60主要特性:
Power system-in-package integrating gate drivers and power MOSFETs featuring: RDS(ON) = 1.38 Ω
BVDSS = 600 V
2 embedded comparators
Very low area occupation, all active devices in SMT technology and no heatsink
Fast-decay or slow-decay on-board constant OFF-time peak current control
PWM voltage mode control with overcurrent protection possible via external logic signals
Driver supply voltage range: 10 V to 20 V
UVLO protection on low-side and high-side
3.3 V to 15 V compatible inputs with hysteresis and pull-down
Internal bootstrap diode
Bill of materials reduction
Very compact and simplified layout
Flexible, easy and fast design
RoHS compliant
Load current up to 1 A
PWD5F60应用:
• Industrial fans and pumps
• Cooking hoods and gas heaters
• Blowers
• Industrial drives and factory automation
• Power supply units
图1.PWD5F60框图
图2.PWD5F60通用应用框图
图3.PWD5F60电流模式马达控制框图
评估板EVALPWD5F60
The EVALPWD5F60 demonstrates how to usethe PWD5F60 to drive a single-phase load in fullbridgetopology. This allows control of both thedirection and the value of the current flowing intothe load. Typical applications that can benefitfrom the high integration of the PWD5F60 are, forexample, single-phase BLDC motors and fans.
The board has a very small footprint and anoptimized layout thanks to the integrated featuresof the PWD5F60, and it can be simply run byapplying the supply voltages and a directionsignal.
The board allows easy selection and modificationof the relevant external component values,enabling fast performance evaluation underdifferent applicative conditions as well as finetuning of final application components.
评估板EVALPWD5F60主要特性:
Power system-in-package integrating gatedrivers and power MOSFETs featuring:
– RDS(ON) = 1.38 Ω
– BVDSS = 600 V
– 2 embedded comparators
Very low area occupation, all active devices inSMT technology and no heatsink
Fast-decay or slow-decay on-board constantOFF-time peak current control
PWM voltage mode control with overcurrentprotection possible via external logic signals
3.3 V to 15 V compatible inputs with hysteresisand pull-down
RoHS compliant
评估板EVALPWD5F60主要指标:
图4.评估板EVALPWD5F60外形图
图5.评估板EVALPWD5F60电路图
评估板EVALPWD5F60材料清单:
图6.评估板EVALPWD5F60 PCB布局图(顶层)
图7.评估板EVALPWD5F60 PCB布局图(底层)
图8.评估板EVALPWD5F60 PCB元件布局图
