Cypress FM4 S6E2C系列32位MCU开发方案
控制/MCU
1921人已加入
Cypress公司的S6E2G系列是32位Arm® Cortex®-M4F FM4微控制器,CPU工作频率高达180MHz,集成了1MB闪存,192KB SRAM,20x通信外设,33x数字外设和3x模拟外设,具有高性能和有竞争力的成本,设计用于工业自动化和测试测量。本文介绍了S6E2G系列主要特性和产品详细特性,框图,以及两种版本开发平台FM4-U120-9B560主要特性和电路图。
FM4-U120-9B560 - Arm® Cortex®-M4 MCU Starter Kit with USB and CMSIS-DAP S6E2G Series are FM4 devices with up to 180 MHz CPU, 1 MB flash, 192 KB SRAM, 20x communication peripherals, 33x digitalperipherals and 3x analog peripherals. They are designed for industrial automation and metering applications.
Devices in the S6E2G Series are highly integrated 32-bit microcontrollers with high performance and competitive cost. This series isbased on the Arm® Cortex®-M4F processor with on-chip flash memory and SRAM. The series has peripherals such as motor controltimers, A/D converters, and communications interfaces (USB, CAN, UART, CSIO (SPI), I2C, LIN)。
S6E2G系列主要特性:
 32-bit Arm Cortex-M4F Core
 Up to 180 MHz frequency operation
 On-chip Memories
 Flash memory: Up to 1024 Kbytes
 SRAM memory:
• SRAM0: up to 128 Kbytes
• SRAM1: 32 Kbytes
• SRAM2: 32 Kbytes
 Direct Memory Access (DMA) Controller (Eight Channels)
 Descriptor System Data Transfer Controller (DSTC);256 channels
 External Bus Interface
 USB Interface (Max two channels): Host and Device
 CAN Interface (Max one channel) Available on S6E2GMand S6E2GH Devices Only
 Multi-function Serial Interface (Max 10 Channels)
 UART (Universal Asynchronous Receiver/Transmitter)
 Clock Synchronous Serial Interface (CSIO (SPI))
 Local Interconnect Network (LIN)
 Inter-Integrated Circuit (I2C)
 Inter-IC Sound (I2S)
 Base Timer (Max 16 channels)
 General Purpose I/O Port
 Up to 121 high-speed general-purpose I/O ports in 144-pinpackage
 Up to 153 high-speed general-purpose I/O ports in 176-pinpackage
 Multi-function Timer (Max two units)
 Real-Time Clock (RTC)
 Analog to Digital Converter (ADC) (Max 32 Channels)
 Dual Timer (32-/16-bit Down Counter)
 Quadrature Position/Revolution Counter (QPRC; Max twochannels)
 Watch Counter
 External Interrupt Controller Unit
 Watchdog Timer (Two channels)
 Cyclic Redundancy Check (CRC) Accelerator
 SD Card Interface Available on S6E2GM, S6E2GH, andS6E2GK Devices Only
 Ethernet-MAC Available on S6E2GM, S6E2GK, andS6E2G2 Devices only
 Smartcard Interface (Max 2 channels)
 Five Clock Sources
 Six Reset Sources
 Clock Supervisor (CSV)
 Low-Voltage Detector (LVD)
 Six Low-power Consumption Modes
 Sleep
 Timer
 RTC
 Stop
 Deep standby RTC
 Deep standby stop
 Peripheral Clock Gating System
 Crypto Assist Function
 Debug
 Serial wire JTAG debug port (SWJ-DP)
 Embedded trace macrocells (ETM) provide comprehensivedebug and trace facilities.
 AHB trace macrocells (HTM)
 41-bit Unique ID
 Wide range voltage: VCC = 2.7 to 5.5 V
32位MCU
图1. S6E2G系列框图
S6E2G系列产品详细特性:
 Up to 180 MHz frequency operation
 FPU built-in
 Support DSP instructions
 Memory protection unit (MPU): improves the reliability of anembedded system
 Integrated nested vectored interrupt controller (NVIC): 1NMI (non-maskable interrupt) and 128 peripheral interruptsand 16 priority levels
 24-bit system timer (Sys Tick): system timer for OS taskmanagement
On-chip Memories
 Flash memory
This series is on-chip flash memories.
 Up to 1024 Kbytes
 Built-in flash accelerator for zero wait state
 Security function for code protection
 SRAM
This is composed of three independent SRAMs (SRAM0,SRAM1 and SRAM2)。 SRAM0 is connected to the I-code busand D-code bus of Cortex-M4F core. SRAM1 and SRAM2
are connected to system bus of Cortex-M4F core.
 SRAM0: up to 128 Kbytes
 SRAM1: 32 Kbytes
 SRAM2: 32 Kbytes
 Supports SRAM, NOR, NAND flash and SDRAM device
 Up to 9 chip selects CS0 to CS8 (CS8 is only for SDRAM)
 8-/16-/32-bit data width
 Up to 25-bit address bus
 Supports address/data multiplexing
 Supports external RDY function
 Supports scramble function
 Possible to set the validity/invalidity of the scramblefunction for the external areas 0x6000_0000 to0xDFFF_FFFF in 4 Mbytes units.
 Possible to set two kinds of the scramble key
USB Interface (Max two channels)
The USB interface is composed of a Device and a Host.
 USB Device
 USB 2.0 Full-speed supported
 Max 6 EndPoint supported
• EndPoint 0 is control transfer
• EndPoint 1,2 can be selected bulk-transfer, interrupttransferor isochronous-transfer
• EndPoint 3 to 5 can select bulk-transfer or interrupttransfer
 EndPoint 1 to 5 comprise double buffer
 The size of each endpoint is as follows.
• Endpoint 0, 2 to 5: 64 byte
• EndPoint 1: 256 byte
 USB Host
 USB2.0 Full-Speed/Low-Speed supported
 Bulk-transfer, interrupt-transfer, and isochronoustransfersupport
 USB Device connected/dis-connected automaticallydetect
 IN/OUT token handshake packet automatically
 Max 256-byte packet length supported
 Wake-up function supported
CAN Interface (Max one channel) Available onS6E2GM and S6E2GH Devices Only
 Compatible with CAN specification 2.0A/B
 Maximum transfer rate: 1 Mbps
 Built-in 32-message buffer
 Separate 64 byte receive and transmit FIFO buffers forchannels 1 and channels 4 to 7.
 Operation mode is selectable for each channel from thefollowing:
 UART
 CSIO (SPI)
 LIN
 I2C
 I2S
 UART
 Full-duplex double buffer
 Selection with or without parity supported
 Built-in dedicated baud rate generator
 External clock available as a serial clock
 Various error detect functions available (parity errors,framing errors, and overrun errors)
 CSIO (SPI)
 Overrun error detect function available
 Serial chip select function (ch 6 and ch 7 only)
 Supports high-speed SPI (ch 4 and ch 6 only)
 Data length 5 to 16-bit
 LIN
 LIN protocol Rev.2.1 supported
 Master/slave mode supported
 LIN break field generation (can change to 13- to 16-bitlength)
 LIN break delimiter generation (can change to 1- to 4-bitlength)
 I2C
 Standard mode (Max 100 kbps)/Fast mode (Max 400 kbps)supported
 Fast mode Plus (Fm+) (Max 1000 kbps, only for ch 3 = ch Aand ch 7 = ch B) supported
 I2S
 Using CSIO (SPI) (ch 1 only) and I2S clock generator
 Supports two transfer protocol: I2S and MSB-justified
 Master mode only
DMA Controller (Eight Channels)
DMA controller has an independent bus, so the CPU andDMA controller can process simultaneously.
 Eight independently configured and operated channels
 Transfer can be started by software or request from thebuilt-in peripherals
 Transfer address area: 32-bit (4 GB)
 Transfer mode: Block transfer/Burst transfer/Demandtransfer
 Transfer data type: bytes/half-word/word
 Transfer block count: 1 to 16
 Number of transfers: 1 to 65536
DSTC (Descriptor System Data Transfer Controller;256 channels)
The DSTC can transfer data at high-speed without going viathe CPU. The DSTC adopts the descriptor system and,following the specified contents of the descriptor that has
already been constructed on the memory, can access directlythe memory/peripheral device and perform the data-transferoperation.
It supports the software activation, the hardware activation,and the chain activation functions.
A/D Converter (Max 32 Channels)
 12-bit A/D Converter
 Successive approximation type
 Built-in three units
 Conversion time: 0.5 μs at 5 V
 Priority conversion available (priority at two levels)
 Scanning conversion mode
 Built-in FIFO for conversion data storage (for SCANconversion: 16 steps, for priority conversion: 4 steps)
Operation mode is selected from the following for eachchannel:
 16-bit PWM timer
 16-bit PPG timer
 16-/32-bit reload timer
 16-/32-bit PWC timer
 Event counter mode (External clock mode)
This series can use its pins as general purpose I/O portswhen they are not used for external bus or peripherals;moreover, the port relocate function is built in. It can set the
I/O port to which the peripheral function can be allocated.
 Capable of pull-up control per pin
 Capable of reading pin level directly
 Built-in port-relocate function
 Up to 121 high-speed general-purpose I/O ports in 144-pinpackage
 Some pins 5 V tolerant I/O.
See 6. Pin Descriptions and 7. I/O Circuit Type for thecorresponding pins.
The multi-function timer is composed of the following blocks:Minimum resolution: 5.56 ns
 16-bit free-run timer × 3 ch/unit
 Input capture × 4 ch/unit
 Output compare × 6 ch/unit
 A/D activation compare × 6 ch/unit
 Waveform generator × 3 ch/unit
 16-bit PPG timer × 3 ch/unit
The following functions can be used to achieve the motorcontrol:
 PWM signal output function
 DC chopper waveform output function
 Dead time function
 Input capture function
 A/D convertor activate function
 DTIF (motor emergency stop) interrupt function
The real-time clock can count year, month, day, hour, minute,second, or day of the week from 00 to 99.
 Interrupt function with specifying date and time(year/month/day/hour/minute) is available. This function isalso available by specifying only year, month, day, hour, or
minute.
 Timer interrupt function after set time or each set time.
 Capable of rewriting the time with continuing the time count.
 Leap year automatic count is available.
Quadrature Position/Revolution Counter (QPRC;Max two channels)
The Quadrature Position/Revolution Counter (QPRC) is usedto measure the position of the position encoder. It is alsopossible to use up/down counter.
 The detection edge of the three external event input pinsAIN, BIN and ZIN is configurable.
 16-bit position counter
 16-bit revolution counter
 Two 16-bit compare registers
The dual timer consists of two programmable 32-/16-bit downcounters.
Operation mode is selectable from the following for eachchannel:
 Free-running
 Periodic (= Reload)
 One shot
Watch Counter
The watch counter is used for wake up from low-powerconsumption mode. It is possible to select the main clock,sub clock, built-in High-speed CR clock, or built-in low-speedCR clock as the clock source.
 Interval timer: up to 64 s (max) with a sub clock of 32.768kHz
 External interrupt input pin: Max 32 pins
 Both edges(Rise edge and Fall edge) detect
 Include one non-maskable interrupt (NMI)
A watchdog timer can generate interrupts or a reset when atime-out value is reached.
This series consists of two different watchdogs: a “hardware”watchdog and a “software” watchdog.
The hardware watchdog timer is clocked by low-speedinternal CR oscillator. The hardware watchdog is thus activein any power saving mode except RTC mode and Stop mode.
The CRC accelerator helps to verify data transmission orstorage integrity.
CCITT CRC16 and IEEE-802.3 CRC32 are supported.
 CCITT CRC16 generator polynomial: 0x1021
 IEEE-802.3 CRC32 generator polynomial: 0x04C11DB7
SD Card Interface Available on S6E2GM, S6E2GH,and S6E2GK Devices Only
It is possible to use the SD card that conforms to thefollowing standards.
 Part 1 Physical Layer Specification version 3.01
 Part E1 SDIO Specification version 3.00
 Part A2 SD Host Controller Standard Specification version3.00
 1-bit or 4-bit data bus
 Compliant with IEEE802.3 specification
 10 Mbps/100 Mbps data transfer rates supported
 MII/RMII for external PHY device supported.
 MII: Max one channel
 RMII: Max one channel
 Full-duplex and half-duplex mode supported.
 Wake-ON-LAN supported
 Built-in dedicated descriptor-system DMAC
 Built-in 2 Kbytes transmit FIFO and 2 Kbytes receive FIFO.
 Compliant IEEE1558-2008 (PTP)
 Compliant with ISO7816-3 specification
 Card Reader only/B class card only
 Available protocols
 Transmitter: 8E2, 8O2, 8N2
 Receiver: 8E1, 8O1, 8N2, 8N1, 9N1
 Inverse mode
 TX/RX FIFO integrated (RX: 16-bytes, TX:16-bytes)
Clock and Reset
 Clocks
Five clock sources (two external oscillators, two internal CRoscillators, and Main PLL) that are dynamically selectable.
 Main clock: 4 MHz to 48 MHz
 Sub clock: 30 kHz to 100 kHz
 High-speed internal CR clock: 4 MHz
 Low-speed internal CR clock: 100 kHz
 Main PLL Clock
 Resets
 Reset requests from INITX pin
 Power on reset
 Software reset
 Watchdog timer reset
 Low-voltage detector reset
 Clock supervisor reset
Clocks generated by internal CR oscillators are used tosupervise abnormality of the external clocks.
 External OSC clock failure (clock stop) is detected, reset isasserted.
 External OSC frequency anomaly is detected, interrupt orreset is asserted.
This Series include two-stage monitoring of voltage on theVCC pins. When the voltage falls below the voltage that hasbeen set, the low-voltage detector function generates an
interrupt or reset.
 LVD1: error reporting via interrupt
 LVD2: auto-reset operation
Six low power consumption modes are supported.
 Sleep
 Timer
 RTC
 Stop
 Deep standby RTC (selectable from with/without RAMretention)
 Deep standby stop (selectable from with/without RAMretention)
The system can reduce the current consumption of the totalsystem with gating the operation clocks of peripheralfunctions not used.
These features are enabled for the crypto assist function.
The dedicated middleware is necessary for this calculatoroperation.
 PKA (Public Key Accelerator)
 PKA(Public Key Accelerator)is modular exponentiationcalculation accelerator used of RSA Public Key crypto andso on.
 Available bit length: Up to 2048-bit
 AES calculator
 AES (Advanced Encryption Standard) calculator is a AEScommon key crypto accelerator which is compliant withFIPS (Federal Information Processing Standard
Publication)197.
 Available key length: 128/192/256-bit
 CBC mode and ECB mode support
 External Bus Data Scramble
 It enables to scramble input/output data of External BusInterface.
Debug
 Serial wire JTAG debug port (SWJ-DP)
 Embedded trace macrocells (ETM) provide comprehensivedebug and trace facilities.
 AHB trace macrocells (HTM)
Unique ID
Unique value of the device (41-bit) is set.
Power Supply
 Four power supplies
 Wide range voltage: VCC = 2.7 V to 5.5 V
 Power supply for USB ch 0 I/O: USBVCC0
= 3.0 V to 3.6 V (when USB is used)
= 2.7 V to 5.5 V (when GPIO is used)
 Power supply for USB ch 1 I/O: USBVCC1
 Power supply for Ethernet-MAC I/O: ETHVCC
= 3.0 V to 5.5 V (when Ethernet is used.)
开发平台FM4-U120-9B560
The FM4-U120-9B560 Starter Kit is a low-cost development platform for the Cypress 160MHz FM4 MB9B560M family of Arm® Cortex®-M4 MCUs. The development kit enables rapid development of high-performance embedded systems by providing peripherals such as USB device, SD card and access to all GPIOs.
Featuring Arm® Cortex®-M4 FM4 MB9B560M MCU160MHz Arm® Cortex® MCU with DMA
Single precision IEEE 754 compliant floating point unit 1MB flash, 128KB SRAM and 100 GPIOs Communication interfaces: USB host, USB device, CAN, LIN, I2S, I2C and UART
开发平台FM4-U120-9B560(-MEM)有两种版本:
32位MCU
图2.开发平台FM4-U120-9B560外形图(正面)
图3.开发平台FM4-U120-9B560外形图(背面)
32位MCU
图4.开发平台FM4-U120-9B560硬件(正面)-跳线概述
32位MCU
图5.开发平台FM4-U120-9B560硬件(正面)-跳线功能概述
32位MCU
图6.开发平台FM4-U120-9B560硬件(背面)
32位MCU
图7.开发平台FM4-U120-9B560电路图(1)
32位MCU
图8.开发平台FM4-U120-9B560电路图(2)
32位MCU
图9.开发平台FM4-U120-9B560电路图(3)
32位MCU
图10.开发平台FM4-U120-9B560电路图(4)
32位MCU
图11.开发平台FM4-U120-9B560电路图(5)
32位MCU
图12.开发平台FM4-U120-9B560电路图(6)
32位MCU
图13.开发平台FM4-U120-9B560电路图(7)
32位MCU
图14.开发平台FM4-U120-9B560电路图(8)
