AD9912 1 GSPS Direct Digital Synthesizer with 14-Bit DAC
KANA 发表于 2019-02-22 15:10:35
数据: AD9912产品技术英文资料手册
优势和特点
  • 1 GSPS internal clock speed (up to 400 MHz output directly)
  • Integrated 1 GSPS 14-bit DAC
  • 48-bit frequency tuning word with 4 μHz resolution
  • Differential HSTL comparator
  • Flexible system clock input accepts either crystal or external reference clock
  • On-chip low noise PLL REFCLK multiplier
  • 2 SpurKiller channels
  • See data sheet for additional information.
产品详情
The AD9912 is a direct digital synthesizer (DDS) that features an integrated 14-bit digital-to-analog converter (DAC). The AD9912 features a 48-bit frequency tuning word (FTW) that can synthesize frequencies in step sizes no larger than 4 μHz. Absolute frequency accuracy can be achieved by adjusting the DAC system clock.
The AD9912 also features an integrated system clock phase-locked loop (PLL) that allows for system clock inputs as low as 25 MHz.
The AD9912 operates over an industrial temperature range, spanning −40°C to +85°C.
Applications
  • Agile LO frequency synthesis
  • Low jitter, fine tune clock generation
  • Test and measurement equipment
  • Wireless base stations and controllers
  • Secure communications
  • Fast frequency hopping
方框图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
