LTC2847 具终端和 3.3V 数字接口的软件可选多协议收发器
KANA 发表于 2019-02-22 13:38:34
数据: LTC2847产品技术英文资料手册
优势和特点
  • Software-Selectable Transceiver Supports: RS232, RS449, EIA530, EIA530-A, V.35, V.36, X.21
  • Operates from Single 5V Supply
  • Separate Supply Pin for Digital Interface Works down to 3V
  • On-Chip Cable Termination
  • Complete DTE or DCE Port with LTC2845
  • Available in 38-Pin 5mm x 7mm QFN Package
产品详情
The LTC®2847 is a 3-driver/3-receiver multiprotocol transceiver with on-chip cable termination. When combined with the LTC2845, this chip set forms a complete softwareselectable DTE or DCE interface port that supports the RS232, RS449, EIA530, EIA530-A, V.35, V.36 and X.21 protocols. All necessary cable termination is provided inside the LTC2847.
The VCC supplies the drivers, the receivers and an internal charge pump that requires only five space-saving surface mounted capacitors. The VIN supply drives the digital interface circuitry including the receiver output drivers. It can be tied to VCC or be powered off a lower supply (down to 3V) to interface with low voltage ASICs. The LTC2847 is available in a 0.8mm tall, 5mm x 7mm QFN package.
应用
  • Data Networking
  • CSU and DSU
  • Data Routers
方框图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
