The Automotive Audio Bus (A2B®) provides a multichannel,I2S/TDM link over distances of up to 15 m between nodes. Itembeds bidirectional synchronous pulse-code modulation(PCM) data (for example, digital audio), clock, and synchronizationsignals onto a single differential wire pair. A2B supports adirect point to point connection and allows multiple, daisychainednodes at different locations to contribute and/or consumetime division multiplexed channel content.
A2B is a single-master, multiple-slave system where the transceiverchip at the host controller is the master. The mastergenerates clock, synchronization, and framing for all slavenodes. The master A2B chip is programmable over a control bus(I2C) for configuration and read back. An extension of this controlbus is embedded in the A2B data stream, which grants directaccess of registers and status information on slave transceiversas well as I2C to I2C communication over distance.
The transceiver can connect directly to general-purpose digitalsignal processors (DSPs), field-programmable gate arrays(FPGAs), application specific integrated circuits (ASICs),microphones, analog-to-digital converters (ADCs), digital-toanalogconverters (DACs), and codecs through a multichannelI2S/TDM interface. It also provides a PDM interface for directconnection of up to four PDM digital microphones.
Finally, the transceiver also supports an A2B bus powering feature,where the master node supplies voltage and current to theslave nodes over the same daisy-chained, twisted pair wire cableas used for the communication link.
Complete technical specifications are available for the A2Btransceiver. Contact your nearest Analog Devices sales office tocomplete the nondisclosure agreement (NDA) required toreceive additional product information.
| Feature | AD2426W | AD2427W | AD2428W |
| Master capable | No | No | Yes |
| Functional TRX blocks | A only | A + B | A + B |
| I2S/TDM support | No | No | Yes |
| PDM microphone inputs | 4 mics | 4 mics | 4 mics |
| Max node to node cable length | 15 m | 15 m | 15 m |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
