AD2426W Automotive Audio Bus A2B Transceiver
KANA 发表于 2019-02-22 13:25:34
数据:
优势和特点
A2B BUS FEATURES
  • Line topology
    • Single master, multiple slave
    • Up to 15 m between nodes and up to 40 m overall cable length
  • Communication over distance
    • Synchronous data
      • Multichannel I2S/TDM to I2S/TDM
      • Clock synchronous, phase aligned in all nodes
      • Low latency slave to slave communication
    • Control and status information I2C to I2C
    • GPIO over distance
  • Bus power or local power slave nodes
  • Configurable with SigmaStudio graphical software tool
  • Qualified for automotive applications
A2B TRANSCEIVER FEATURES
  • Configurable as A2B bus master or slave (AD2428W)
  • I2C interface
  • 8-bit to 32-bit multichannel I2S/TDM interface
    • I2S/TDM/PDM programmable data rate
    • Up to 32 upstream and 32 downstream channels
  • PDM inputs for 4 high dynamic range microphones on masters or slaves
  • Support for receiving I2S data on nodes with up to 4 PDM microphones
  • Unique ID register for each transceiver
  • Support for crossover or straight-through cabling
  • Programmable settings to optimize EMC performance
产品详情
The Automotive Audio Bus (A2B®) provides a multichannel,I2S/TDM link over distances of up to 15 m between nodes. Itembeds bidirectional synchronous pulse-code modulation(PCM) data (for example, digital audio), clock, and synchronizationsignals onto a single differential wire pair. A2B supports adirect point to point connection and allows multiple, daisychainednodes at different locations to contribute and/or consumetime division multiplexed channel content.
A2B is a single-master, multiple-slave system where the transceiverchip at the host controller is the master. The mastergenerates clock, synchronization, and framing for all slavenodes. The master A2B chip is programmable over a control bus(I2C) for configuration and read back. An extension of this controlbus is embedded in the A2B data stream, which grants directaccess of registers and status information on slave transceiversas well as I2C to I2C communication over distance.
The transceiver can connect directly to general-purpose digitalsignal processors (DSPs), field-programmable gate arrays(FPGAs), application specific integrated circuits (ASICs),microphones, analog-to-digital converters (ADCs), digital-toanalogconverters (DACs), and codecs through a multichannelI2S/TDM interface. It also provides a PDM interface for directconnection of up to four PDM digital microphones.
Finally, the transceiver also supports an A2B bus powering feature,where the master node supplies voltage and current to theslave nodes over the same daisy-chained, twisted pair wire cableas used for the communication link.
Complete technical specifications are available for the A2Btransceiver. Contact your nearest Analog Devices sales office tocomplete the nondisclosure agreement (NDA) required toreceive additional product information.
Table 1. Product Comparison Guide
Feature AD2426W AD2427W AD2428W
Master capable No No Yes
Functional TRX blocks A only A + B A + B
I2S/TDM support No No Yes
PDM microphone inputs 4 mics 4 mics 4 mics
Max node to node cable length 15 m 15 m 15 m
Applications
  • Automotive audio communication link
  • Active noise cancellation
  • Microphone arrays for hands free and in car communication
方框图
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
