RH101A Operational Amplifier
KANA 发表于 2019-02-22 12:11:34
数据: RH101A产品技术英文资料手册
优势和特点
  • mV Max VOS
  • Average Temperature Coefficient: 15µV/°C
  • Input Offset Current: 20nA Max
  • Input Bias Current: 100nA Max
  • CMMR and PSRR: 80dB
  • Wide Supply Range: ±15V to ±20V
  • Input Supply Current: 2.5 mA
Radiation Performance
  • Total Ionizing Dose (TID) Tolerance, per TM1019.8, MIL-STD- 883:
    • 200kRad (Si), per condition A at 50Rads(Si)/sec
    • Displacement Damage Defect (DDD) up to 1E12 Neutrons/cm2
产品详情
The RH101A is a general purpose operational amplifier featuring low bias current and the ability to operate with high input differential voltages. Unlike many FET input amplifiers, the output of the RH101A does not reverse if the common mode range is exceeded, making them particularly useful in comparator and oscillator circuits. The RH101A uses external compensation, allowing the frequency response and slew rate to be optimized for the application.
The wafer lots are processed to our in house Class S flow to yield circuits usable in stringent military and space applications.
Third Party Vendor Availability
We partner with third party vendors who assemble and test packaged products with RH Dice inside.
For MSK prefix products please click on the Part Number in the table below and scroll down the linked page to find the part number.
Part Number Description   SMD
MSK0041RH   General Purpose Class C Op Amp (0.5A peak output) -
MSK106RH General Purpose Class C Op Amp (2A peak output) 5962-11228
方框图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
