可编程逻辑
关键词: ALTERA , Stratix IV GT 100G
Altera公司的Stratix IV 40nm FPGA包括Stratix IV E, Stratix IV GX和Stratix IV GT三个系列, 具有最高的密度(680K 逻辑单元(LE),22.4 Mbits 嵌入式存储器和1,360个18 x 18 乘法器),最佳的性能以及最低的功耗, 系统带宽(8.5 Gbps的48 个高速收发器,以及 1,067 Mbps (533 MHz) DDR3存储器接口)达到了前所未有的水平,并具有优异的信号完整性, 非常适合无线通信,固网,军事,广播等其他最终市场中的高端数字应用。本文介绍了Stratix® IV FPGA主要特性, Stratix IV GT器件框图,以及采用EP4S100G5F45I1 Stratix IV GT FPGA器件的Stratix IV GT 100G开发板主要特性,方框图,详细电路图和材料清单.
2012-2-28 08:44:51 上传
Altera® Stratix® IV FPGAs deliver a breakthrough level of system bandwidth and power efficiency for high-end applications, allowing you to innovate without compromise. Stratix IV FPGAs are based on the Taiwan Semiconductor Manufacturing Company (TSMC) 40-nm process technology and surpass all other high-end FPGAs, with the highest logic density, most transceivers, and lowest power requirements.
The Stratix IV device family contains three optimized variants to meet different application requirements:
■ Stratix IV E (Enhanced) FPGAs—up to 813,050 logic elements (LEs), 33,294 kilobits
(Kb) RAM, and 1,288 18 x 18 bit multipliers
■ Stratix IV GX transceiver FPGAs—up to 531,200 LEs, 27,376 Kb RAM, 1,288 18 x 18-bit multipliers, and 48 full-duplex clock data recovery (CDR)-based transceivers at up to 8.5 Gbps
■ Stratix IV GT—up to 531,200 LEs, 27,376 Kb RAM, 1,288 18 x 18-bit multipliers, and 48 full-duplex CDR-based transceivers at up to 11.3 Gbps
Stratix® IV FPGA主要特性:
The following list summarizes the Stratix IV device family features:
■ Up to 48 full-duplex CDR-based transceivers in Stratix IV GX and GT devices supporting data rates up to 8.5 Gbps and 11.3 Gbps, respectively
■ Dedicated circuitry to support physical layer functionality for popular serial protocols, such as PCI Express (PCIe) (PIPE) Gen1 and Gen2, Gbps Ethernet (GbE), Serial RapidIO, SONET/SDH, XAUI/HiGig, (OIF) CEI-6G, SD/HD/3G-SDI, Fibre Channel, SFI-5, and Interlaken
■ Complete PCIe protocol solution with embedded PCIe hard IP blocks that implement PHY-MAC layer, Data Link layer, and Transaction layer functionality
■ Programmable transmitter pre-emphasis and receiver equalization circuitry to compensate for frequency-dependent losses in the physical medium
■ Typical physical medium attachment (PMA) power consumption of 100 mW at 3.125 Gbps and 135 mW at 6.375 Gbps per channel
■ 72,600 to 813,050 equivalent LEs per device
■ 7,370 to 33,294 Kb of enhanced TriMatrix memory consisting of three RAM block sizes to implement true dual-port memory and FIFO buffers
■ High-speed digital signal processing (DSP) blocks configurable as 9 x 9-bit, 12 x 12-bit, 18 x 18-bit, and 36 x 36-bit full-precision multipliers at up to 600 MHz
■ Up to 16 global clocks (GCLK), 88 regional clocks (RCLK), and 132 periphery clocks (PCLK) per device
■ Programmable power technology that minimizes power while maximizing device performance
■ Up to 1,120 user I/O pins arranged in 24 modular I/O banks that support a wide range of single-ended and differential I/O standards
■ Support for high-speed external memory interfaces including DDR, DDR2, DDR3 SDRAM, RLDRAM II, QDR II, and QDR II+ SRAM on up to 24 modular I/O banks
■ High-speed LVDS I/O support with serializer/deserializer (SERDES), dynamic phase alignment (DPA), and soft-CDR circuitry at data rates up to 1.6 Gbps
■ Support for source-synchronous bus standards, including SGMII, GbE, SPI-4 Phase 2 (POS-PHY Level 4), SFI-4.1, XSBI, UTOPIA IV, NPSI, and CSIX-L1
■ Pinouts for Stratix IV E devices designed to allow migration of designs from Stratix III to Stratix IV E with minimal PCB impact
Stratix IV GT Devices
Stratix IV GT devices provide up to 48 CDR-based transceiver channels per device:
■ Thirty-two out of the 48 transceiver channels have dedicated PCS and PMA circuitry and support data rates between 600 Mbps and 11.3 Gbps
■ The remaining 16 transceiver channels have dedicated PMA-only circuitry and support data rates between 600 Mbps and 6.5 Gbps
下载附件 (19.34 KB)
下载附件 (31.13 KB)
下载附件 (14.78 KB)
下载附件 (37.49 KB)
下载附件 (114.28 KB)
下载附件 (914 Bytes) Stratix IV GT 100G开发板电路图.pdf (1.74 MB, 下载次数: 0)
2012-2-28 08:44:17 上传
下载次数: 0
下载附件 (138 Bytes) Stratix IV GT 100G开发板材料清单.rar (20.85 KB, 下载次数: 0)
2012-2-28 08:42:15 上传
下载次数: 0
2012-2-28 08:35:43 上传
下载次数: 0
2012-2-28 08:35:32 上传
下载次数: 0全部0条评论
