移动通信
关键词: LED , LNK457DG , Powerint , 电源
Powerint公司的7W B10 LED灯电源采用LinkSwitch-PL系列的LNK457DG,具有单级PFC和精确的恒流(CC)输出以及低成本元件少与小尺寸的特点,AC输入电压90V-132V,115VAC时的效率大于90%,PF大于0.95,集成了无负载检测/短路保护,热关断自动恢复,可替代B10白炽灯。本文介绍了LinkSwitch-PL系列产品亮点,方框图,典型应用电路以及7W PFC LED驱动器指标,电路图,材料清单和PCB布局图。
2012-4-12 15:01:25 上传
The LinkSwitch-PL family enables a very small and low cost single-stage power factor corrected constant current driver for solid state lighting. Optimized for direct LED current sensing, the LinkSwitch-PL operates over a wide input voltage range delivering an output power of up to 16 W. The LinkSwitch-PL control algorithm provides flicker-free TRIAC dimming with minimal external components.
Each device incorporates a 725 V rated power MOSFET, a novel discontinuous mode variable frequency variable on-time controller, frequency jitter, cycle by cycle current limit and hysteretic thermal shutdown in a monolithic 4-pin IC, available in SO-8C, eSOP-12, and eDIP-12 packages.
LinkSwitch-PL系列产品亮点:
Dramatically Simplifies Off-line LED Drivers
• Flicker-free phase-controlled TRIAC dimming
• Single stage power factor correction and accurate constant current (CC) output
• Very low component count with small non-electrolytic bulk capacitor for compact replacement lamp designs
• Compact SO8, eSOP, and eDIP packages
• Completely eliminates control loop compensation
Advanced Performance Features
• Optimized for non-isolated flyback designs
• Frequency jitter greatly reduces EMI filter size and costs
• Low dissipation direct sensing of LED current
Advanced Protection and Safety Features
• Cycle skipping regulation for abnormally low output power to clamp peak output current delivered
• 725 V integrated power MOSFET allows small bulk capacitance and maximizes power capability
• Short-circuit, overload, open feedback and output overvoltage protection
• Hysteretic thermal shutdown
• Meets high-voltage creepage between DRAIN and all other pins both on PCB and at package EcoSmart™ - Energy Efficient
• High power factor optimizes system lumen per input VA
• Control algorithm balances switching and conduction losses over line and load to maintain optimum efficiency
下载附件 (12.43 KB)
下载附件 (21.93 KB)
下载附件 (105.85 KB)
下载附件 (53.7 KB)
下载附件 (33.96 KB)
下载附件 (25.62 KB)
下载附件 (70.38 KB)
下载附件 (40.18 KB)
下载附件 (54.21 KB)
2012-4-12 15:01:24 上传
下载次数: 3全部0条评论
