移动通信
关键词: ICLS8082G , Infineon , LED , PFC
Infineon公司的 ICLS8082G是集成了800 V CoolMOS®带PFC和调光的离线LED控制器,功率因速大于98%,和其它通用的解决方案相比,效率有大幅度提高,器件工作电压高达26V,功耗低.并具有多种安全保障.主要用在100W / 60W / 40W 白炽灯泡替代,LED灯管等. 本文介绍了ICLS8082G产品亮点和主要特性,方框图,典型应用电路以及评估板EVAL-LED-ICLS8082G-B2主要特性和指标,电路图,材料清单,变压器设计图与PCB元件布局图.
2012-3-15 12:59:28 上传
Offline LED Controller For PFC And Dimming With Integrated 800 V CoolMOS®
The ICLS8082G employs a quasi-resonant operation mode optimized for off-line LED lighting, especially for dimmable LED bulbs for replacement of incandescent lamps.
Precise PWM generation enables primary control for phase-cut dimming and high power factors (PF) > 98 %. It offers significantly improved driver efficiency, up to 90 %, compared to other conventional solutions. The product has a wide operation range (up to 26 V) of IC voltage supply and lower power consumption. Multiple safety functions ensure full system protection in failure situations.
With its full feature set and simple application, the ICLS8082G represents an outstanding choice for quasiresonant flyback LED bulb designs combining the feature set and performance at minimum BOM cost.
ICLS8082G产品亮点:
• Quasi-resonant control for highly efficient LED driving solutions
• Primary-side flyback control with integrated PFC and phase-cut dimming
• High-voltage CoolMOS® and startup cell for short "time to light"
• Best-in-class system BOM for dimmable LED bulbs with the integrated CoolMOS®
• Miniatuarization with the integrated CoolMOS®
ICLS8082G主要特性:
• High, stable efficiency over a wide operating range
• Optimized for trailing- and leading-edge dimmers
• Precise PWM for primary PFC and dimming control
• Startup cell for Vcc precharging with constant current
• Built-in digital soft start
• Foldback correction and cycle-by-cycle peak current limitation
• VCC over/undervoltage lockout
• Auto restart mode for short-circuit protection
• Adjustable latch-off mode for output overvoltage protection
ICLS8082G应用:
100W / 60W / 40W incandescent bulb replacement
Lamp retrofits, LED tubes / luminaires, downlights „ „
下载附件 (20.91 KB)
下载附件 (78.95 KB)
下载附件 (32.45 KB)
下载附件 (10.22 KB)
下载附件 (20.74 KB)
下载附件 (62.25 KB)
下载附件 (77.18 KB)
下载附件 (17.24 KB)
下载附件 (25.23 KB)
2012-3-15 12:57:01 上传
下载次数: 9
2012-3-15 12:57:39 上传
下载次数: 9全部0条评论
