MAX28200优势特性以及基本应用电路
控制/MCU
1933人已加入
Maxim公司的MAX28200是低功耗16位MAXQ MCU(μC),包括了功能强大的16位RISC微控制器(MCU)以及10位93.75ksps ADC与I2C通信端口;还包括GPIO引脚。器件还集成了16KB闪存和2KB数据SRAM.此外实用的ROM空间包括宏命令如I2C引导加载程序,使得闪存固件能在现场升级。器件还提供NIST SP 800-185兼容的安全散列算法(SHA-3)KMAC挑战和响应身份验证,并能和其它SHA-3设备配对。工作电压1.71V到3.63V,工作温度-40℃ 到 +85℃,主要用在智能手机和消费类电子产品。本文介绍了MAX28200优势和主要特性,应用框图和基本应用电路,以及评估板MAX28200 EVK主要特性,电路图,材料清单和PCB装配布局图。
The MAX28200 is a low-power, 16-bit MAXQ® microcontroller (μC) designed for low-power applications, including smart phones and consumer electronics. The device combines a powerful 16-bit RISC microcontroller with a 10-bit, 93.75ksps ADC along with an I2C communications port. The device includes four GPIO pins. The device includes 16KB of flash memory and 2KB of data SRAM. Additional utility ROM space includes macros such as an I2C bootloader to enable flash memory firmware updates in the field. The device provides NIST SP 800-185 compliant secure hash algorithm (SHA-3) KMAC challenge and response authentication and can be paired with other SHA-3 devices.
For the ultimate in low-power battery-operated performance, the device includes an ultra-low-power stop mode. In this mode, the minimum amount of circuitry is powered. The device wakes up on a matching I2C address. Wake-up sources also include external interrupts, the power-fail warning, and a wake-up timer interrupts. The microcontroller runs from a wide 1.71V to 3.63V operating voltage.
MAX28200优势和主要特性:
High-Performance, Low-Power, 16-Bit RISC Core
Internal 12MHz Oscillator Requires No External Components
Two-Channel, 10-Bit 93.75ksps ADC
I2C Slave Peripheral 400kHz Operating Frequency
Flash Bootloader Function
Wakeup from Ultra-Low Power Stop Mode on I2C Address Match
16-Bit PWM Timer Output
Wake-Up Timer
SHA-3 KMAC Secure Authentication with RNG
1.71V to 3.63V Operating Voltage
16-Bit Instruction Word, 16-Bit Data Bus
Memory Features16KB Flash Memory
2KB Data SRAM
-40℃ to +85℃ Operating Temperature
Low Power Consumption0.2μA (typ), 2.0μA (max) in Stop Mode, TA = +25℃, Power-Fail Monitor Disabled
2.7mA (typ) at 12MHz in Active Mode
1.7mm x 1.8mm x 0.5mm 12-Bump WLP Package
MAX28200应用:
Smartphones
Consumer Electronics
Maxim
图1.MAX28200应用框图
Maxim
图2.MAX28200基本应用电路
评估板MAX28200 EVK
The MAX28200 evaluation kit (EV kit) provides a devel­opment platform that provides access to all the features of the MAX28200 in a tiny, easy to use board. The ROM-based bootloader is accessed through JTAG or an I2C interface. Connectors are provided for a host bus adapter, the DS9481P programming tool, and for JTAG. Board power can be supplied by USB, host bus adapter, JTAG, or the DS9481P programming tool. This board provides a powerful processing subsystem in a very small space that can be easily integrated into a variety of applications.
评估板MAX28200 EVK主要特性:
MAX28200 Microcontroller MAXQ20 16-Bit Core
16KB Flash Memory
2KB SRAM
PWM/Timer
2-Channel, 10-Bit ADC
I2C
Hardware SHA-3 Engine
Comparator
Integrated Peripherals Status LEDs
Temperature Sensor
Potentiometer
评估板MAX28200 EVK包括:
MAX28200 EV Kit Board with a Sample Device Preprogrammed with Demo
DS9481P-300# Programming Tool
USB Type A to Micro-B Cable
图3.评估板MAX28200 EVK外形图
Maxim
图4.评估板MAX28200 EVK电路图(1)
Maxim
图5.评估板MAX28200 EVK电路图(2)
Maxim
图6.评估板MAX28200 EVK电路图(3)
评估板MAX28200 EVK材料清单:
Maxim
Maxim
图7.评估板MAX28200 EVK PCB装配布局图
