Powerint LNK417EG 15W LED驱动解决方案
移动通信
312人已加入
关键词: LED驱动 , LNK417EG , Powerint
Powerint公司的15W LED驱动器采用LinkSwitchTM-PH LNK417EG器件和±3% CC调整,具有高效率,功率因素大于0.9,AC输入电压90V-265V,满足IEC 61000-4-5环形波, IEC 61000-3-2 Class C谐波和EN55015 B接触EMI要求,起动时间小于100ms.本文介绍了该驱动器主要特性和指标, 驱动器和子板电路图以及相应的材料清单与PCB布局图.
This document describes an isolated, power factor corrected, very high efficiency LED driver (non-dimmable) designed to drive an LED string of 30 V at a current of 500 mA(both nominal) from an input voltage range of 90 VAC to 265 VAC. The design employs a secondary side current feedback circuit to achieve less than 3% output current regulation over line and load. A reference board DER-284 was used with the secondary constant current regulation daughter board added to demonstrate how this technique can be used on and LinkSwitch-PH flyback design.
The LED driver uses a LNK417EG device from the LinkSwitch-PH family of ICs. This integrated controller and 725 V MOSFET dramatically reduces complexity and omponent count.
This document contains the LED driver specification, schematic, and bill of material,transformer documentation and typical performance characteristics.
15W LED驱动器主要特性:
≤3% output current regulation over line and load
Highly energy efficient
Efficiency ≥88% at 115 VAC and 230 VAC input
Low cost, low component count and small printed circuit board footprint solution
Frequency jitter for smaller, lower cost EMI filter components
Integrated protection and reliability features
Output open-circuit / output short-circuit protection with auto-recovery
Line input overvoltage shutdown extends voltage withstand during line faults.
Auto-recovering thermal shutdown with large hysteresis protects both components
and printed circuit board
No damage during brown-in or brown-out conditions
Meets IEC 61000-4-5 ring wave, IEC 61000-3-2 Class C harmonics and EN55015 B conducted EMI
Clean start-up – no output blinking
Fast start-up (<100 ms) – no perceptible delay
2011-11-22 16:00:01 上传
下载附件 (28.48 KB)
图1.15W LED驱动器外形图
15W LED驱动器指标:
下载附件 (31.23 KB)
下载附件 (28.34 KB)
图2.15W LED驱动器电路图
下载附件 (20.96 KB)
图3.15W LED驱动器子板电路图
下载附件 (29.81 KB)
图4.15W LED驱动器PCB布局图
下载附件 (35.79 KB)
图5.子板PCB布局图
15W LED驱动器材料清单:
下载附件 (94.87 KB)
子板材料清单:
下载附件 (15.02 KB)
下载附件 (32.89 KB)
下载附件 (10.42 KB)
图6.变压器电路图
详情请见:
der289.pdf (3.11 MB, 下载次数: 0)
2011-11-22 15:59:45 上传
下载次数: 0
下载积分: 积分 -1
  • 相关推荐
  • 热点推荐
