The OPA124 is a precision monolithic FET opera- tional amplifier using a Difet (dielectrical isolation) manufacturing process. Outstanding DC and AC per- formance characteristics allow its use in the most critical instrumentation applications. Bias current, noise, voltage offset, drift, open-loop gain, common-mode rejection and power supply re- jection are superior to BIFET and CMOS amplifiers. Difet fabrication achieves extremely low input bias currents without compromising input voltage noise performance. Low input bias current is maintained over a wide input common-mode voltage range with unique cascode circuitry. This cascode design also allows high precision input specifications and reduced susceptibility to flicker noise. Laser trimming of thin- film resistors gives very low offset and drift. Compared to the popular OPA111, the OPA124 gives comparable performance and is available in an 8-pin PDIP and 8-pin SOIC package.
