linux多线程之pthread用法
嵌入式技术
1418人已加入
#include
int pthread_create(pthread_t *restrict tidp,const pthread_attr_t *restrict attr,
void *(*start_rtn)(void),void *restrict arg);
Returns: 0 if OK, error number on failure
Linux
第一个参数为指向线程标识符的指针。
第二个参数用来设置线程属性。
第三个参数是线程运行函数的起始地址。
第四个参数是运行函数的参数。
当创建线程成功时,函数返回0,若不为0则说明创建线程失败,常见的错误返回代码为EAGAIN和EINVAL。前者表示系统限制创建新的线程,例如线程数目过多了;后者表示第二个参数代表的线程属性值非法.
pthread_create的用法:由于pthread库不是Linux系统默认的库,所以在使用pthread_create创建线程时,需要在编译中请加-lpthread参数,eg:gcc -o test -lpthrea test.c
例1:
#include "pthread.h"
#include "stdio.h"
void* thread_test(void* ptr)
{ while(1)
printf("i am pthread\n");
int main()
pthread_t pid;
pthread_create(&pid, NULL, test_thread, NULL);
while(1)
printf("i am main pthread\n");
return 0;
例2:
#include
#include
pthread_t id;
int ret;
void thread_1()
while(1)
{printf(“I am thread\n”);
sleep(1);
main()
{ret = pthread_create(&id,NULL,(void*)thread_1,NULL);
if(ret != 0)
printf("Create pthread error!\n");
while(1)
printf(“I am main thread\n”);
sleep(2);
例3:
#include
#include
#include
#include
void *thread_function(void *arg);
char message[] = "Hello World";
int main()
int res;
pthread_t a_thread;
void *thread_result;
res = pthread_create(&a_thread, NULL, thread_function, (void *)message);
if (res != 0)
perror("Thread creation failed");
exit(EXIT_FAILURE);
printf("Waiting for thread to finish...\n");
res = pthread_join(a_thread, &thread_result); //pthread_join 阻塞执行的线程直到某线程结束
if (res != 0)
perror("Thread join failed");
exit(EXIT_FAILURE);
printf("Thread joined, it returned %s\n", (char *)thread_result);
printf("Message is now %s\n", message);
exit(EXIT_SUCCESS);
printf("thread_function is running. Argument was %s\n", (char *)arg);
sleep(3);
strcpy(message, "Bye!");
pthread_exit("Thank you for the CPU time");
[iyunv@plinux tmp]# cc -D_REENTRANT -I/usr/include/nptl thread2.c -o thread2 -L/usr/lib/nptl -lpthread
[iyunv@plinux tmp]# ./thread2
thread_function is running. Argument was Hello World
Thread joined, it returned Thank you for the CPU time
Message is now Bye!
pthread_join()
void pthread_exit(void *retval)
int pthread_join(pthread_t pid, void **thread_return)
pthread_join()的调用者将挂起并等待th线程终止,retval是调用pthread_exit()的线程(线程ID为pid)的返回值,如果thread_return不为NULL,则*thread_return=retval。
需要注意的是一个线程仅允许唯一的另一个线程使用 pthread_join()等待本线程的终止,并且被等待的线程应该处于可join状态,即非DETACHED状态。
