Embeded linux中的MMC驱动
嵌入式技术
1418人已加入
一、注册平台设备
platform_device_register(&usr_mci_device);
二、填写平台设备结构体
static struct platform_device usr_mci_device= {
.name          = "xxx",
.id             = 0,
.dev = {
.release     = usr_mci_platdev_release,
.dma_mask  = &usr_mmc_dmamask,
.coherent_dma_mask = DMA_BIT_MASK(32),
.num_resources    = ARRAY_SIZE(usr_mci_resources),
.resource          = usr_mci_resources,
三、填写资源结构体(物理地址查芯片手册)
static struct resource usr_mci_resources[] = {
[0] = {
.start          = CONFIG_USR_IOBASE,
.end            = CONFIG_USR_IOBASE + USR_MCI_IO_SIZE - 1,
.flags          = IORESOURCE_MEM,
[1] = {
.start          = CONFIG_USR_INTR,
.end            = CONFIG_USR_INTR,
.flags          = IORESOURCE_IRQ,
四、注册平台驱动
platform_driver_register(&usr_mci_driver);
五、填写平台驱动结构体
static struct platform_driver usr_mci_driver= {
.probe = usr_mci_probe,
.remove = usr_mci_remove,
.suspend = usr_mci_suspend,
.resume = usr_mci_resume,
.driver = {
.name = DRIVER_NAME,
六、重写probe函数
static int __devinit usr_mci_probe(struct platform_device *pdev)
七、创建一个自己的设备结构体
struct usr_host {
struct mmc_host *mmc;
spinlock_t lock;
struct mmc_request *mrq;
struct mmc_command *cmd;
struct mmc_data *data;
void __iomem *base;
unsigned int card_status;
struct scatterlist *dma_sg;
unsigned int dma_sg_num;
unsigned int dma_alloc_size;
unsigned int dma_dir;
dma_addr_t dma_paddr;
unsigned int *dma_vaddr;
struct timer_list timer;
unsigned int irq;
unsigned int irq_status;
unsigned int is_tuning;
wait_queue_head_t intr_wait;
unsigned long pending_events;
unsigned int id;
struct usr_host *host;
八、分配一个包含了mmc_host的自定义结构体(core需要)
mmc = mmc_alloc_host(sizeof(struct usr_host), &pdev->dev);
九、初始化mmc_host结构体
mmc->ops
mmc->f_min
mmc->f_max
mmc->caps
mmc->max_blk_count
mmc->max_segs
mmc->max_seg_size
mmc->max_req_size
mmc->ocr_avail
mmc->ocr
十、初始化usr_host
host=mmc->private;
host->dma_vaddr = dma_alloc_coherent(&pdev->dev, PAGE_SIZE,&host->dma_paddr, GFP_KERNEL);
host->mmc = mmc;
host->id
host->base
十一、初始化SDIO的时钟、驱动能力
十二、SDIO复位
十三、SDIO重上电
十四、设置时钟相位
十五、设置阈值
十六、设置中断状态
十七、设置中断屏蔽
十八、设置DMA搬移数据
十九、设置全局中断使能
二十、设置FIFO突发长度与FIFO大小
二十一、卡检测
二十二、初始化定时器,定时处理函数为卡检测
二十三、获取资源结构体的软中断号
二十四、初始化等待队列
init_waitqueue_head(&host->intr_wait);
二十五、request_irq注册中断
二十六、写中断函数(唤醒等待队列)
static irqreturn_t usr_irq(int irq, void *dev_id)
wake_up(&host->intr_wait);
