了解Embeded linux的摄像头驱动问题
嵌入式技术
1418人已加入
一、摄像头平台层
drivers\media\video\mxc\capture\mxc_v4l2_capture.c
module_init(camera_init);
随后,进行加载下一个驱动,如果遇到摄像头设备层对应驱动,举例adv7180解码芯片
drivers\media\video\mxc\capture\adv7180.c
module_init(adv7180_init);
static __init int adv7180_init(void)
   u8 err = i2c_add_driver(&adv7180_i2c_driver);
return err;
static struct i2c_driver adv7180_i2c_driver = {
   .driver = {
       .owner = THIS_MODULE,
       .name = "adv7180",
   .probe = adv7180_probe,
   .remove = adv7180_detach,
   .id_table = adv7180_id,
static __init int camera_init(void)
u8 err = platform_driver_register(&mxc_v4l2_driver);//将mxc_v4l2_driver这个驱动注册到platform平台上面,如果有匹配的设备的话,就会调用到mxc_v4l2_driver里面的probe函数
return err;
static struct platform_driver mxc_v4l2_driver = {
   .driver = {
       .name = "mxc_v4l2_capture",
   .probe = mxc_v4l2_probe,
   .remove = mxc_v4l2_remove,
   .suspend = mxc_v4l2_suspend,
   .resume = mxc_v4l2_resume,
   .shutdown = NULL,
*struct platform_device {
 *  const char * name;
 *  int  id;
 *  struct device dev;
 *  u32  num_resources;
 *  struct resource * resource;
 *  const struct platform_device_id *id_entry;
 *  struct mfd_cell *mfd_cell;
 *  struct pdev_archdata archdata;
static int mxc_v4l2_probe(struct platform_device *pdev)
cam_data *cam = kmalloc(sizeof(cam_data), GFP_KERNEL);
init_camera_struct(cam, pdev);//初始化cam_data结构体
v4l2_int_device_register(cam->self);
/*私有数据的结构体关系
*struct cam_data           drivers\media\video\mxc\capture\mxc_v4l2_capture.h
 *->struct video_device       include\media\v4l2-dev.h
 *   ->struct device      include\linux\device.h
 *     ->struct device_private   drivers\base\base.h
 *       ->void *driver_data;
static void init_camera_struct(cam_data *cam, struct platform_device *pdev)
cam->video_dev = video_device_alloc();//分配一个video_device结构体
*(cam->video_dev) = mxc_v4l_template;//设置ops操作->v4l2_file_operations->mxc_v4l_ioctl->mxc_v4l_do_ioctl->VIDIOC_*_IOCTL:{...}
video_set_drvdata(cam->video_dev, cam);//将cam设置为cam->video_dev的私有数据->dev_set_drvdata -> dev->p->driver_data = data;
cam->crop_bounds.left = 0;           //这里只是初始化crop参数默认值
cam->crop_bounds.width = 640;
cam->crop_bounds.top = 0;
cam->crop_bounds.height = 480;
cam->crop_current = cam->crop_defrect = cam->crop_bounds;
cam->enc_callback = camera_callback;
cam->self = kmalloc(sizeof(struct v4l2_int_device), GFP_KERNEL);
cam->self->module = THIS_MODULE;
cam->self->type = v4l2_int_type_master;
cam->self->u.master = &mxc_v4l2_master;//后面会调用
int v4l2_int_device_register(struct v4l2_int_device *d)
v4l2_int_device_try_attach_all();
void v4l2_int_device_try_attach_all(void)
struct v4l2_int_device *m, *s;
list_for_each_entry(m, &int_list, head)
if (m->type != v4l2_int_type_master) continue;//从int_list链表中取出type类型为v4l2_int_type_master的结构体保存在m中
list_for_each_entry(s, &int_list, head)
if (s->type != v4l2_int_type_slave)continue;//从int_list链表中取出type类型为v4l2_int_type_slave的结构体保存在s中
if (s->u.slave->master)continue;//如果存在s->u.slave->master则跳过继续寻找
s->u.slave->master = m;//找到master设备和第一个没有设置master的slave设备,并将从设备的master设置为找到的master
if (m->u.master->attach(s))//调用m的u.master->atach(s)函数,即cam->self->u.master = &mxc_v4l2_master;设置的函数
static struct v4l2_int_master mxc_v4l2_master = {
.attach = mxc_v4l2_master_attach,
.detach = mxc_v4l2_master_detach,
static int mxc_v4l2_master_attach(struct v4l2_int_device *slave)
cam->crop_bounds.top = cam->crop_bounds.left = 0;//crop参数都是根据slave结构体来设置的,这里是根据真正slave设备中获取到的参数来填充crop参数
   cam->crop_bounds.width = cam_fmt.fmt.pix.width;
   cam->crop_bounds.height = cam_fmt.fmt.pix.height;
cam->crop_defrect.top = cam->crop_defrect.left = 0;
 cam->crop_defrect.width = cam_fmt.fmt.pix.width;
   cam->crop_defrect.height = cam_fmt.fmt.pix.height;
cam->crop_current.top = cam->crop_current.left = 0;
   cam->crop_current.width = cam_fmt.fmt.pix.width;
   cam->crop_current.height = cam_fmt.fmt.pix.height;
