你知道Uboot中的net是怎样的?
嵌入式技术
1418人已加入
//net读
//api/api.c
static cfp_t calls_table[API_MAXCALL] = { NULL, };
void api_init(void)
calls_table[API_RSVD] = NULL;
calls_table[API_GETC] = &API_getc;
calls_table[API_PUTC] = &API_putc;
calls_table[API_TSTC] = &API_tstc;
calls_table[API_PUTS] = &API_puts;
calls_table[API_RESET] = &API_reset;
calls_table[API_GET_SYS_INFO] = &API_get_sys_info;
calls_table[API_UDELAY] = &API_udelay;
calls_table[API_GET_TIMER] = &API_get_timer;
calls_table[API_DEV_ENUM] = &API_dev_enum;
calls_table[API_DEV_OPEN] = &API_dev_open;
calls_table[API_DEV_CLOSE] = &API_dev_close;
calls_table[API_DEV_READ] = &API_dev_read;
calls_table[API_DEV_WRITE] = &API_dev_write;
calls_table[API_ENV_GET] = &API_env_get;
calls_table[API_ENV_SET] = &API_env_set;
calls_table[API_ENV_ENUM] = &API_env_enum;
calls_no = API_MAXCALL;
static int API_dev_read(va_list ap)
else if (di->type & DEV_TYP_NET)
len_net = (int *)va_arg(ap, u_int32_t);
if (!len_net)
return API_EINVAL;
if (*len_net <= 0)
return API_EINVAL;
act_len_net = (int *)va_arg(ap, u_int32_t);
if (!act_len_net)
return API_EINVAL;
*act_len_net = dev_read_net(di->cookie, buf, *len_net);
//api/api_net.c
int dev_read_net(void *cookie, void *buf, int len)
return eth_receive(buf, len);
//net/eth.c
int eth_receive(volatile void *packet, int length)
if (eth_rcv_current == eth_rcv_last)
push_packet = eth_save_packet;
eth_rx();
push_packet = pp;
return -1;
//drivers\net\higmacv300\Higmac.c
int eth_rx(void)
NetReceive(NetRxPackets[0], len);
//net/net.c
void NetReceive(volatile uchar * inpkt, int len)
x = ntohs(vet->vet_type);
switch (x)
case PROT_ARP:
switch (ntohs(arp->ar_op))
case ARPOP_REQUEST:
case ARPOP_REPLY:
tmp = NetReadIP(&arp->ar_data[6]);
if (tmp == NetArpWaitReplyIP)
(*packetHandler)(0,0,0,0);
case PROT_RARP:
case PROT_IP:
if (ip->ip_p == IPPROTO_ICMP)
switch (icmph->type)
case ICMP_REDIRECT:
case ICMP_ECHO_REPLY:
case ICMP_ECHO_REQUEST:
static rxhand_f *packetHandler; /* Current RX packet handler */
void NetSetHandler(rxhand_f * f)
packetHandler = f;
//net/net.h
typedef void rxhand_f(uchar *, unsigned, unsigned, unsigned);
举例tftp通讯
//net/tftp.c
void TftpStart (void)
NetSetHandler (TftpHandler);
static void TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len)
s = (ushort *)pkt;
proto = *s++;
switch (ntohs(proto))
case TFTP_RRQ:
case TFTP_WRQ:
break;
case TFTP_ACK:
好记性不如烂笔头
