【站友投递】IIC的範例程式
嵌入式技术
1411人已加入
 * IIC初始值 function
void i2c_init(void)
  // unsigned char slave_address;  //CTP Slave address set
    //IICADD
      //slave_address=0x38;    //Device slave address
      //GPE set 55555515
      *(volatile unsigned int *)GPECON=0xF5555515;//set GPE15->IICSDA  GPE14->IICSCL
      *(volatile unsigned int *)GPECON=0xA5555515;//set GPE15->IICSDA  GPE14->IICSCL
      *(volatile unsigned int *)GPEUP=0xC00f ;     //GPE3=CTP Interrupt
      //IIC Initial
      *(volatile unsigned int *)0x54000008 = 0x38; // S3C2410A to IIC Save address
      *(volatile unsigned int *)0x54000000 = 0xAF; // ACK &IIC中斷,IICCLK=MCLK/16 ,ACK=fPCLK/16//(15+1)
      *(volatile unsigned int *)0x54000004 = 0x10; // Enable Tx/i2c_master_RX
 * I2C Master TX function
void i2c_master_TX(unsigned char slave_add,unsigned char add1)
    unsigned char i=0;
   *(volatile unsigned int *)0x54000004 = 0xD0; // Master Tx mode
   *(volatile unsigned int *)0x5400000C = slave_add; // Master to Slave address
   *(volatile unsigned int *)0x54000004= 0xF0;//IICSTAT (M/R START) bit5 IIC Start single產生
         while((*(volatile unsigned char *)(0x54000000)&0x10 )!=0x10){;;} //Tx/i2c_master_RX Interrupt Enable
         *(volatile unsigned char *) 0x5400000C=add1 ;//Writer A DATA
         *(volatile unsigned int *)0x54000000=0xAF;  //Interrupt pending =0
         *(volatile unsigned int *)0x54000004=0xD0;//STOP
         *(volatile unsigned int *)0x54000000=0xAF;//ACK
         Delay1us(10);
 * I2C Master Receiver function read 26 byte
void i2c_master_RX(unsigned char slave_add) //
  unsigned int i=0;
  unsigned int temp1;
  unsigned char check_sum;
   *(volatile unsigned int *)0x54000004 = 0x90; // Master i2c_master_RX mode
   *(volatile unsigned int *)0x54000004=0xB0;//IICSTAT (M/R START)bit5 IIC Start single產生
    while((*(volatile unsigned char *)(0x54000000) &0x10 )!=0x10){;;} //Tx/i2c_master_RX Interrupt Enable
    for(i=0;i<25;i++)
          data1[i]=*(volatile unsigned char *) 0x5400000C ;//READ A DATA
         *(volatile unsigned int *)0x54000000=0xAF;  //Interrupt pending =0             }
            data1[25]=*(volatile unsigned char *)0x5400000C ;//READ 最後一筆資料 DATA
            *(volatile unsigned int *)0x54000004=0x90;//STOP
            *(volatile unsigned int *)0x54000000=0x2F;//NACK
             Delay1us(10);
  • 相关推荐
  • 热点推荐
