基于48MHz Arm® Cortex®-M0+ MCU的微控制器
  nxp公司的KE1xZ64是基于48 MHz Arm® Cortex®-M0+ MCU的微控制器,提供多达64KB闪存,多达8KB RAM以及完整的模拟/数字特性,并具有用于工业网络强健的触摸感应接口(TSI)和CAN总线,在定制的家用电器触摸UI和工业控制系统提供高度稳定性和精确度。其ARM CortexR-M0+核基于ARMv6架构和ThumbR-2 ISA,支持高达48MHz频率,具有可配置嵌套矢量中断控制器(NVIC),存储器映射除法和平方根模块(MMDVSQ),电源管理控制器(PMC)具有多种模式:运行,等待,停止,VLPR, VLPW和VLPS;工作电压2.7V-5.5V,环境温度–40 到105℃,主要用在消费类电子,工业控制和工业网络。本文介绍了KE1xZ64主要特性,功能框图和系统框图,时钟框图,以及评估板FRDM-KE16Z主要特性,框图和电路图和PCB设计图。
  Providing up to 64 KB flash, up to 8 KB RAM, and a complete setof analog/digital features, KE1xZ64 offers a robust Touch SenseInterface (TSI) and CAN bus for industrial networking, whichprovides high-level stability and accuracy in customer ’s homeappliance touch UI and industrial control systems.
  KE1xZ64主要特性:
  Core Processor and System
  • ArmR CortexR-M0+ core, supports up to 48 MH***requency
  • Arm Core based on the ARMv6 Architecture andThumbR-2 ISA
  • Configurable Nested Vectored Interrupt Controller(NVIC)
  • Memory-Mapped Divide and Square Root module(MMDVSQ)
  Reliability, safety and security
  • Cyclic Redundancy Check (CRC) generator module
  • 128-bit unique identification (ID) number
  • Internal watchdog (WDOG) with independent clocksource
  • External watchdog monitor (EWM) module
  • ADC self calibration feature
  • On-chip clock loss monitoring
  Power management
  • Low-power Arm Cortex-M0+ core with excellent energyefficiency
  • Power management controller (PMC) with multiplepower modes: Run, Wait, Stop, VLPR, VLPW andVLPS
  • Supports clock gating for unused modules, and specificperipherals remain working in low power modes
  • POR, LVD/LVR
  Memory and memory interfaces
  • Up to 64 KB program flash
  • Up to 8 KB SRAM
  • 64 Bytes flash cache
  Mixed-signal analog
  • 1× 12-bit analog-to-digital converter (ADC) with upto 16 channel analog inputs per module, up to 1Msps
  • 1× high-speed analog comparators (CMP) withinternal 8-bit digital to analog converter (DAC)
  Timing and control
  • 2× Flex Timers (FTM) for PWM generation, offering6ch+2ch
  • 1× 16-bit Low-Power Timer (LPTMR) with flexiblewake up control
  • 1× Programmable Delay Block (PDB) with flexibletrigger system
  • 1× 32-bit Low-power Periodic Interrupt Timer (LPIT)with 2 independent channels
  • Real timer clock (RTC)
  Debug functionality
  • Serial Wire Debug (SWD) debug interface
  • Debug Watchpoint and Trace (DWT)
  • Micro Trace Buffer (MTB)
  Clock interfaces
  • OSC: high range 4 - 40 MHz (with low power or highgainmode) and low range 32 - 40 kHz (with high-gainmode only)
  • 48 MHz high-accuracy (up to ±1%) fast internalreference clock (FIRC) for normal Run
  • 8 MHz / 2 MHz high-accuracy (up to ±3%) slow internalreference clock (SIRC) for low-speed Run
  • 128 kHz low power oscillator (LPO)
  • Low-power FLL (LPFLL)
  • Up to 50 MHz DC external square wave input clock
  • System clock generator (SCG)
  • Real time counter (RTC)
  Human-machine interface (HMI)
  • Supports up to 32 interrupt request (IRQ) sources
  • Up to 42 GPIO pins with interrupt functionality
  • Touch sensing input (TSI) module
  Connectivity and communications interfaces
  • 3× low-power universal asynchronous receiver/transmitter (LPUART) modules with FIFO supportand low power availability
  • 1× low-power serial peripheral interface (LPSPI)modules with FIFO support and low poweravailability
  • 1× low-power inter-integrated circuit (LPI2C)modules with FIFO support and low power availability
  • 1× CAN module (MSCAN), with 5 Rx buffers and 3Tx buffers
  Operating Characteristics
  • Voltage range: 2.7 to 5.5 V
  • Ambient temperature range: –40 to 105℃
微控制器
  图1.KE1xZ64功能框图
  Kinetis KE1xZ64子系列产品
微控制器
  图2.Kinetis KE1xZ64系统框图
微控制器
  图3.Kinetis KE1xZ64时钟框图
  评估板FRDM-KE16Z
  The FRDM-KE16Z Freedom board is designed to work in standalone mode oras the main board of FRDM-TOUCH, FRDM-MC-LVBLDC, and Arduinoboards. The FRDM-KE16Z Freedom board is a modular development platformthat enables rapid prototyping and tool reuse through reconfigurable hardware.
  评估板FRDM-KE16Z主要特性:
  • MKE16Z64VLF4 MCU (Arm? Cortex?-M0+ core, 48 MHz clock, 64 KBFlash, 8 KB RAM, 48 LQFP package)
  • I/O headers for easy access to MCU I/O pins
  • Compatible with FRDM-TOUCH, FRDM-MC-LVBLDC, and Arduinoboards
  • On-board debug circuit: MK20DX128VFM5 (OpenSDA) with virtual serialport
  • NXP inertial sensor, FXOS8700CQ
  • Reset pushbutton, two user buttons, and one RGB LED
  • Touch electrodes in self-capacitive mode
  图4.评估板FRDM-KE16Z顶层外形图
微控制器
  图5.评估板FRDM-KE16Z框图
  The FRDM-KE16Z features the KE16Z64VLF4 MCU. This 48 MHz microcontroller is part of the Kinetis KE+ family and isimplemented in a 64 LQFP package.
  评估板FRDM-KE16Z MCU主要特性:
  • 32-bit Arm Cortex-M0+ core, 48 MHz
  • Memories
  — 64 KB flash
  — 8 KB SRAM
  • Clocks
  — Clock generation module with FLL for system and core clock generation
  — 48 MHz high accuracy fast internal reference clock (FIRC)
  — 8 MHz/2 MHz high accuracy slow internal reference clock (SIRC)
  — 4-40 MHz fast external oscillator (OSC)
  — 128 KHz low-power oscillator (LPO)
  — Low-power FLL (LPFLL)
  • Analog peripherals
  — 1 x 12-bit SAR ADC with up to 16 channels input per module
  — 1 x high-speed analog comparators (CMP) with internal 8-bit digital to analog converter (DAC)
  • Connectivity and communications interfaces
  — 1 x low-power serial peripheral interface (LPSPI)
  — 1 x low-power inter-integrated circuit (LPI2C) module
  — 3 x low-power universal asynchronous receiver/transmitter (LPUART) modules
  — 1 x CAN module (MSCAN), with 5 receive buffers and 3 transmit buffers
  ◦ Timers
  — 2 x FlexTimer (FTM) modules
  — 1 x 16-bit low-power timer(LPTMR) with flexible wake-up control
  — 1 x 32-bit Periodic Interrupt Timer(LPIT)
  — 1 x Programmable Delay Block(PDB) with flexible trigger system
  — Real-time clock (RTC)
  • Human-machine interface (HMI)
  — Supports up to 32 interrupt request (IRQ) sources
  — Up to 42 GPIO pins with interrupt functionality
  — 25-channel touch sensing interface(TSI), supporting both self-capacitive and mutual-capacitive mode
  图6.评估板FRDM-KE16Z电路图(1)
微控制器
  图7.评估板FRDM-KE16Z电路图(2)
微控制器
  图8.评估板FRDM-KE16Z电路图(3)
微控制器
  图9.评估板FRDM-KE16Z电路图(4)
微控制器
  图10.评估板FRDM-KE16Z电路图(5)
微控制器
  图11.评估板FRDM-KE16Z PCB设计图(1)
微控制器
  图12.评估板FRDM-KE16Z PCB设计图(2)
微控制器
  图13.评估板FRDM-KE16Z PCB设计图(3)
微控制器
  图14.评估板FRDM-KE16Z PCB设计图(4)
微控制器
  图15.评估板FRDM-KE16Z PCB设计图(5)
微控制器
  图16.评估板FRDM-KE16Z PCB设计图(6)
微控制器
  图17.评估板FRDM-KE16Z PCB设计图(7)
微控制器
  图18.评估板FRDM-KE16Z PCB设计图(8)
微控制器
  图19.评估板FRDM-KE16Z PCB设计图(9)
微控制器
  图20.评估板FRDM-KE16Z PCB设计图(10)
微控制器
  图21.评估板FRDM-KE16Z PCB设计图(11)
  详情请见:
  https://www.nxp.com/docs/en/data-sheet/KE1xZP48M48SF0.pdf
  和https://www.nxp.com/docs/en/user-guide/UM11204.pdf
  UM11204.pdf
