LMC6081-MIL 精密CMOS单路运算放大器
KANA 发表于 2019-04-18 20:33:09
数据: LMC6081-MIL中文资料.pdf
产品信息
描述 The LMC6081 is a precision low offset voltage operational amplifier, capable of single supply operation. Performance characteristics include ultra low input bias current, high voltage gain, rail-to-rail output swing, and an input common mode voltage range that includes ground. These features, plus its low offset voltage, make the LMC6081 ideally suited for precision circuit applications.Other applications using the LMC6081 include precision full-wave rectifiers, integrators, references, and sample-and-hold circuits.This device is built with TI's advanced Double-Poly Silicon-Gate CMOS process.For designs with more critical power demands, see the LMC6061 precision micropower operational amplifier.For a dual or quad operational amplifier with similar features, see the LMC6082 or LMC6084 respectively.特性 (Typical unless otherwise stated) Low offset voltage:  150 μV Operates from 4.5V to 15V single supply Ultra low input bias current: 10 fA Output swing to within 20 mV of supply rail, 100k load Input common-mode range includes V− High voltage gain: 130 dB Improved latchup immunity All trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
