LM1458-MIL 双运算放大器
KANA 发表于 2019-04-18 20:31:09
数据: LM1458-MIL中文资料.pdf
产品信息
描述 The LM1458 and the LM1558 are general purpose dual operational amplifiers. The two amplifiers share a common bias network and power supply leads. Otherwise, their operation is completely independent.The LM1458 is identical to the LM1558 except that the LM1458 has its specifications guaranteed over the temperature range from 0°C to +70°C instead of −55°C to +125°C.特性No Frequency Compensation Required Short-Circuit Protection Wide Common-Mode and Differential Voltage Ranges Low-Power Consumption 8-Lead TO-99 and 8-Lead PDIP No Latch Up When Input Common Mode Range is Exceeded All trademarks are the property of their respective owners.
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
