LM614-MIL 四路运算放大器和可调参考
KANA 发表于 2019-04-18 19:03:09
数据: LM614-MIL中文资料.pdf
产品信息
描述 The LM614 consists of four op-amps and a programmable voltage reference in a 16-pin package. The op-amp out-performs most single-supply op-amps by providing higher speed and bandwidth along with low supply current. This device was specifically designed to lower cost and board space requirements in transducer, test, measurement and data acquisition systems.Combining a stable voltage reference with four wide output swing op-amps makes the LM614 ideal for single supply transducers, signal conditioning and bridge driving where large common-mode-signals are common. The voltage reference consists of a reliable band-gap design that maintains low dynamic output impedance (1Ω typical), initial tolerance (2.0%), and the ability to be programmed from 1.2V to 5.0V via two external resistors. The voltage reference is very stable even when driving large capacitive loads, as are commonly encountered in CMOS data acquisition systems.As a member of TI's new Super-Block family, the LM614 is a space-saving monolithic alternative to a multichip solution, offering a high level of integration without sacrificing performance.特性Op Amp Low Operating Current: 450μA Wide Supply Voltage Range: 4V to 36V Wide Common-Mode Range: V − to (V+− 1.8V) Wide Differential Input Voltage: ±36V Reference Adjustable Output Voltage: 1.2V to 5.0V Initial Tolerance: ±2.0% Wide Operating Current Range: 17μA to 20mA Tolerant of Load Capacitance All trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
