LM556 双路计时器
KANA 发表于 2019-04-18 19:03:09
数据: LM556中文资料.pdf
产品信息
描述 The LM556 dual-timing circuit is a highly-stable controller capable of producing accurate time delays or oscillation. The LM556 device is a dual-timing version of the LM555 device. Timing is provided by an external resistor and capacitor for each timing function. The two timers operate independently of each other, sharing only VCC and ground. The circuits may be triggered and reset on falling waveforms. The output structures may sink or source 200 mA.特性Direct Replacement for SE556/NE556 Timing From Microseconds Through Hours Operates in Both Astable and Monostable Modes Replaces Two 555 Timers Adjustable Duty Cycle Output Can Source or Sink 200 mA Output and Supply TTL-Compatible Temperature Stability Better Than 0.005% per °C Normally On and Normally Off Output
电路图、引脚图和封装图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
