LF411-N 低偏移、低漂移 JFET 输入运算放大器
KANA 发表于 2019-04-18 20:28:10
数据: LF411-N中文资料.pdf
产品信息
描述 These devices are low-cost, high-speed, JFET input operational amplifiers with very low input offset voltage and input offset voltage drift. They require low supply current yet maintain a large gain bandwidth product and fast slew rate. In addition, well matched high voltage JFET input devices provide very low input bias and offset currents. The LF411 is pin compatible with the standard LM741 allowing designers to immediately upgrade the overall performance of existing designs.These amplifiers may be used in applications such as high speed integrators, fast D/A converters, sample and hold circuits and many other circuits requiring low input offset voltage and drift, low input bias current, high input impedance, high slew rate and wide bandwidth.特性Internally Trimmed Offset Voltage: 0.5 mV (Max) Input Offset Voltage Drift: 7 µV/°C (Typ) Low Input Bias Current: 50 pA Low Input Noise Current: 0.01 pA/√Hz Wide Gain Bandwidth: 3 MHz (Min) High Slew Rate: 10 V/µs (Min) Low Supply Current: 1.8 mA High Input Impedance: 1012Ω Low Total Harmonic Distortion: ≤0.02% Low 1/ƒ Noise Corner: 50 Hz Fast Settling Time to 0.01%: 2 µs
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
