LM336-2.5-N 电压参考二极管
KANA 发表于 2019-04-18 20:24:09
数据: LM336-2.5-N中文资料.pdf
产品信息
描述 The LM136-2.5/LM236-2.5 and LM336-2.5 integrated circuits are precision 2.5V shunt regulator diodes. These monolithic IC voltage references operate as a low-temperature-coefficient 2.5V zener with 0.2Ω dynamic impedance. A third terminal on the LM136-2.5 allows the reference voltage and temperature coefficient to be trimmed easily.The LM136-2.5 series is useful as a precision 2.5V low voltage reference for digital voltmeters, power supplies or op amp circuitry. The 2.5V make it convenient to obtain a stable reference from 5V logic supplies. Further, since the LM136-2.5 operates as a shunt regulator, it can be used as either a positive or negative voltage reference.The LM136-2.5 is rated for operation over –55°C to +125°C while the LM236-2.5 is rated over a –25°C to +85°C temperature range.The LM336-2.5 is rated for operation over a 0°C to +70°C temperature range. See the connection diagrams for available packages.特性 Low temperature coefficient Wide operating current of 400 µA to 10 mA 0.2Ω dynamic impedance ±1% initial tolerance available Guaranteed temperature stability Easily trimmed for minimum temperature drift Fast turn-on
电路图、引脚图和封装图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
