THS1007 10 位 6MSPS 同步采样四路通道 ADC;包含并行 DSP/uP I/F 通道 自动扫描
KANA 发表于 2019-04-18 19:06:09
数据: THS1007中文资料.pdf
产品信息
描述 The THS1007 is a CMOS, low-power, 10-bit, 6 MSPS analog-to-digital converter (ADC). The speed, resolution, bandwidth, and single-supply operation are suited for applications in radar, imaging, high-speed acquisition, and communications. A multistage pipelined architecture with output error correction logic provides for no missing codes over the full operating temperature range. Internal control registers are used to program the ADC into the desired mode. The THS1007 consists of four analog inputs, which are sampled simultaneously. These inputs can be selected individually and configured to single-ended or differential inputs. Internal reference voltages for the ADC (1.5 V and 3.5 V) are provided. An external reference can also be chosen to suit the dc accuracy and temperature drift requirements of the application. The THS1007C is characterized for operation from 0°C to 70°C, and the THS1007I is characterized for operation from –40°C to 85°C.特性 Simultaneous Sampling of 4 Single-Ended Signals or 2 Differential Signals or Combination of Both Signal-to-Noise and Distortion Ratio: 59 dB at fI = 2 MHz Differential Nonlinearity Error: ±1 LSB Integral Nonlinearity Error: ±1 LSB Auto-Scan Mode for 2, 3, or 4 Inputs 3-V or 5-V Digital Interface Compatible Low Power: 216 mW Max at 5 V Power Down: 1 mW Max 5-V Analog Single Supply Operation Internal Voltage References . . . 50 PPM/°C and ±5% Accuracy Glueless DSP Interface Parallel µC/DSP Interface APPLICATIONS Radar Applications Communications Control Applications High-Speed DSP Front-End Automotive Applications
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
