TLV2545 12 位 200 kSPS ADC 系列 输出,TMS320 兼容(最高 10MHz)单通道 伪差动
KANA 发表于 2019-04-18 20:10:10
数据: TLV2545中文资料.pdf
产品信息
描述The TLV2541, TLV2542, and TLV2545 are a family of high performance, 12-bit, low power, miniature, CMOS analog-to-digital converters (ADC). The TLV254x family operates from a single 2.7-V to 5.5-V supply. Devices are available with single, dual, or single pseudo-differential inputs. Each device has a chip select (CS), serial clock (SCLK), and serial data output (SDO) that provides a direct 3-wire interface to the serial port of most popular host microprocessors (SPI interface). When interfaced with a TMS320™ DSP, a frame sync signal (FS) can be used to indicate the start of a serial data frame on CS for all devices or FS for the TLV2541. TLV2541, TLV2542, and TLV2545 are designed to operate with very low power consumption. The power saving feature is further enhanced with an autopower-down mode. This product family features a high-speed serial link to modern host processors with SCLK up to 20 MHz. The maximum SCLK frequency is dependent upon the mode of operation (see Table 1). The TLV254x family uses the built-in oscillator as the conversion clock, providing a 3.5-µs conversion time.特性 Maximum Throughput . . . 140/200 KSPS Built-In Conversion Clock INL/DNL: ±1 LSB Max, SINAD: 72 dB, SFDR: 85 dB, fi = 20 kHz SPI/DSP-Compatible Serial Interface Single Supply: 2.7 Vdc to 5.5 Vdc Rail-to-Rail Analog Input With 500 kHz BW Three Options Available: TLV2541: Single Channel Input TLV2542: Dual Channels With Autosweep TLV2545: Single Channel With Pseudo-Differential Input Low Power With Autopower Down Operating Current: 1 mA at 2.7 V, 1.5 mA at 5 V Autopower Down: 2 µA at 2.7 V, 5 µA at 5 V Small 8-Pin MSOP and SOIC PackagesTMS320 is a trademark of Texas Instruments.
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
