TLV1548-Q1 具有串行控制和 8 个模拟输入的汽车类低压 10 位模数转换器
KANA 发表于 2019-04-18 20:09:09
数据: TLV1548-Q1中文资料.pdf
产品信息
描述The TLV1548 is a CMOS 10-bit switched-capacitor successive-approximation (SAR) analog-to-digital (A/D) converter. The device has a chip select (CS), input-output clock (I/O CLK), data input (DATA IN) and serial data output (DATA OUT) that provides a direct 4-wire synchronous serial peripheral interface (SPI™, QSPI™) port of a host microprocessor. When interfacing with a TMS320 DSP, an additional frame sync signal (FS) indicates the start of a serial data frame. The device allows high-speed data transfers from the host. The INV CLK\ input provides further timing flexibility for the serial interface. In addition to a high-speed converter and versatile control capability, the device has an on-chip 11-channel multiplexer that can select any one of eight analog inputs or any one of three internal self-test voltages. The sample-and-hold function is automatic except for the extended sampling cycle, where the sampling cycle is started by the falling edge of asynchronous CSTART. At the end of the A/D conversion, the end-of-conversion (EOC) output goes high to indicate that the conversion is complete. The TLV1548 is designed to operate with a wide range of supply voltages with very low power consumption. The power saving feature is further enhanced with a software-programmed power-down mode and conversion rate. The converter incorporated in the device features differential high-impedance reference inputs that facilitate ratiometric conversion, scaling, and isolation of analog circuitry from logic and supply noise. A switched-capacitor design allows low-error conversion over the full operating temperature range. The TLV1548 has eight analog input channels. The TLV1548Q is characterized for operation over the full automotive temperature range of –40°C to 125°C.特性Qualified for Automotive Applications ESD Protection Exceeds 2000 V Per MIL-STD-883, Method 3015; Exceeds 200 V Using Machine Model (C = 200 pF, R = 0) Conversion Time ≤ 10 µs 10-Bit-Resolution ADC Programmable Power-Down Mode . . . 1 µA Wide Range Single-Supply Operation of 2.7 V dc to 5.5 V dc Analog Input Range of 0 V to VCC Built-in Analog Multiplexer with 8 Analog Input Channels TMS320 DSP and Microprocessor SPI and QSPI Compatible Serial Interfaces End-of-Conversion (EOC) Flag Inherent Sample-and-Hold Function Built-In Self-Test Modes Programmable Power and Conversion Rate Asynchronous Start of Conversion for Extended Sampling Hardware I/O Clock Phase Adjust InputSPI and QSPI are registered trademarks of Motorola, Inc.
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
