TLC3544 14 位、5V、200KSPS、4 通道单级性 ADC
KANA 发表于 2019-04-18 20:08:09
数据: TLC3544中文资料.pdf
产品信息
描述The TLC3544 and TLC3548 are a family of 14-bit resolution high-performance, low-power, CMOS analog-to-digital converters (ADC). All devices operate from a single 5-V analog power supply and 3-V to 5-V digital supply. The serial interface consists of four digital inputs [chip select (CS\), frame sync (FS), serial input-output clock (SCLK), serial data input (SDI)], and a 3-state serial data output (SDO). CS\ (works as SS\, slave select), SDI, SDO, and SCLK form an SPI interface. FS, SDI, SDO, and SCLK form a DSP interface. The frame sync signal (FS) indicates the start of a serial data frame being transferred. When multiple converters connect to one serial port of a DSP, CS\ works as the chip select to allow the host DSP to access the individual converter. CS\ can be tied to ground if only one converter is used. FS must be tied to DVDD if it is not used (such as in an SPI interface). When SDI is tied to DVDD, the device is set in hardware default mode after power-on, and no software configuration is required. In the simplest case, only three wires (SDO, SCLK, and CS\ or FS) are needed to interface with the host. In addition to being a high-speed ADC with versatile control capability, these devices have an on-chip analog multiplexer (MUX) that can select any analog input or one of three self-test voltages. The sample-and-hold function is automatically started after the fourth SCLK (normal sampling) or can be controlled by CSTART\ to extend the sampling period (extended sampling). The normal sampling period can also be programmed as short sampling (12 SCLKs) or long sampling (44 SCLKs) to accommodate the faster SCLK operation popular among high-performance signal processors. The TLC3544 and TLC3548 are designed to operate with low power consumption. The power saving feature is further enhanced with software power-down/ autopower-down modes and programmable conversion speeds. The conversion clock (internal OSC) is built in. The converter can also use an external SCLK as the conversion clock for maximum flexibility. The TLC3544 and TLC3548 have a 4-V internal reference. The converters are specified with unipolar input range of 0-V to 5-V when a 5-V external reference is used.特性14-Bit Resolution Maximum Throughput 200 KSPS Analog Input Range 0-V to Reference Voltage Multiple Analog Inputs: 8 Channels for TLC3548 4 Channels for TLC3544 Pseudodifferential Analog Inputs SPI/DSP-Compatible Serial Interfaces With SCLK up to 25 MHz Single 5-V Analog Supply; 3-/5-V Digital Supply Low Power: 4 mA (Internal Reference: 1.8 mA) for Normal Operation 20 µA in Autopower-Down Built-In 4-V Reference, Conversion Clock and 8x FIFO Hardware-Controlled and Programmable Sampling Period Programmable Autochannel Sweep and Repeat Hardware Default Configuration INL: ±1 LSB Max DNL: ±1 LSB Max SINAD: 80.8 dB THD: –95 dB
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
