nRF24V1 Getting Started Guide
消耗积分:3 | 格式:rar | 大小:4444 | 2008-10-05
479461
分享资料个
The Headset Reference Design kit contains the following hardware:
• Headset (x2)
• Batteries (x4)
• Antenna (x2)
• USB dongle (x1)
• ISP cable (x1) (not shown in picture)
• Headset application board (x1)
• Audio application board (x1)
Using the headset with the USB dongle
Follow the intructions below to set up the headset application board:
1. Remove the headset application board (marked “Headset”) from the box.
2. Screw one of the supplied antennas into the antenna port (marked CJ1) on the headset application
board.
3. Unpack two batteries and place them in the battery holders on the headset application board
ensuring correct polarity.
4. Insert the headset’s microphone cable into the AUDIO IN interface.
5. Insert the headset’s audio cable into the AUDIO OUT interface.
6. Make sure switch 6 (SW6) is set to BAT if you are using the batteries provided.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
