Introducing the nRF24E1 transceiver with embedded 8051 MCU, 9 channel 12-bit ADC, and peripherals - the industry's most complete wireless 2.4GHz ISM band platform
Based on the market leading nRF2401, the nRF24E1 brings the level of integration one step further. In a unique market leading design, the most sophisticated low cost 2.4GHz ISM wireless component is paired with the industry standard 8051 MCU core, and leading peripherals to create the worlds first complete low cost System on Chip (SoC) IC's for global 2.4GHz operation.
nRF24E1 is manufactured in an ultra modern 0.18µm process, and have included all the great benefits of the nRF2401, such as ShockBurst", DuoCeiver", on-chip CRC and address computation/encoding.
Global application enabler - low cost and small size
The entire radio, 8051 MCU, 9 channel 12 bit ADC, peripherals, inductors and filters, are integrated on a single die which gives the highest value and smallest Bill of Material (BoM) available in the market today. The only external components needed to make a complete system are a crystal, resistor, and a low cost external 4KB EEPROM for initial program storage. The total solution fits into a 36-pin QFN package, measuring 6x6mm.
Using the worldwide 2.4GHz frequency band the nRF24E1 eliminates the need for several hardware platforms to cover a global market -easing logistics and ensuring portability for products.
下载资料需要登录,并消耗一定积分。
全部1条评论
管理员回复: 现在已经解决了 感谢您的反馈 收起回复
