移动存储介质监控系统的设计
消耗积分:5 | 格式:rar | 大小:1857 | 2010-12-14
郑成枝
分享资料个
 移动存储介质由于体积小,容量大,使用便利等优点应用广泛,但在保密单位如果缺乏有效的监管措施,极易导致泄密。设计了一种涉密移动存储介质监控系统,该系统由上位机服务器与下位机构成,前者为主流计算机,后者包括ARM主板、读卡器、报警器等。该系统结构简单,成本低廉,可有效监控移动存储介质,减少泄密。
Abstract:
 Owing to small package,large capability and convenience,the mobile memory mediums are widely used. But they will lose secrets if lack of effective management in secret departments. Based on these considerations,we design a system for monitoring mobile memory mediums relating to secrets. This system is composed of a server and a device,the former is a popular computer and the latter contains an ARM board,a card reader and an annunciator.The system is cheap and simply constructed and will monitor the mobile memory mediums effectively to reduce losing secrets.
评论(0)
发评论
下载排行榜
