A new color LCD display system is introduced in this paper.The embedded 32-bit multimedia microprocessor SPCE3200 designed by Sunplus company is used as controller and LQ057Q3DC02 color TFT LCD designed by Sharp company is used for displayer by the system.Image data will be wrote into buffer from Flash after decoding by built-in MPEG4/JPEG hardware module.And then the data in the buffer will be transmitted into LCD with the help of data transfer clock,frame synchronization clock and line synchronous clock,which are produced by LCD.The hardware and software design are given.
