MVC模式在嵌入式调试工具开发中的研究
消耗积分:5 | 格式:rar | 大小:550 | 2011-01-05
李霞
分享资料个
模型—视图—控制器MVC(Model-View-Controller)模式是系统开发中较常用的一种开发模式。将MVC思想引入开发模式中,先对MVC架构进行了讨论,然后通过基于Eclipse插件开发技术开发的嵌入式调试工具对MVC架构模式的应用进行相关阐述。实际开发表明:通过MVC 模式可以清晰地分离出人机界面、业务逻辑与数据处理,整个调试系统具有良好的运行性、可扩展性和易维护性。
Abstract:
 MVC(Model-View-Controller) pattern is the most commonly used development model in system development.This paper introduced the MVC ideas into the model of software development.Firstly,it discussed the MVC pattern.Then through the application of embedded debugging tool which based on Eclipse plug-in technology, it discussed how to implement the MVC architecture pattern.The actual development shows that through the MVC pattern clearly separates out the human-machine interface,business logic and data processing.The debug system has good performability,expansibility and maintainability.
评论(0)
发评论
下载排行榜
