CharimanBattery美国Chariman蓄电池总代理生产备用型、起动型、动力型全系列的铅酸蒂电池,包括:AGM阀控式密封铅酸蓄电池,胶体(GEL)视控式密封铅酸幕电池,纯铅电池:UPS用高功率系列电池,船舶用电池,铁路用电池,启停电池,汽车用铅酸蓄电池,摩托车用铅酸蓄电池,OPzV、OPzS、PzSPzV PzB管式极板铅韵蓄电池,高尔夫球车用铅酸蓄电池,扫地车电池,电动助力车用铅酸蕃电池等系列产品产品广泛应用于通信、电力、广电、铁路、太阳能、UPS 应急灯、安防、报警、园艺工具、汽车、摩托车、高尔夫球车、叉车、电动车、童车等十几个相关产业,年生产能力总和超过1100万千伏安时
Terminals - Copper Alloy Threaded Inserts for improved electrical connections.
Terminals are recessed to prevent short circuits across wheelchair battery connections.
Chairman AGM Deep Cycle Wheel Chair Batteries
Terminal protectors are now available for after connection protection.
New cover is a flat top design-No protruding or exposed vent valves.
Built in lifting Handles.
Reinforced container walls to reduce bulging.
High Impact Strength Polypropylene Case and Cover.
Valve Regulated Construction.
Immobilized Electrolyte - Non-Spillable.
Maintenance Free Design Never Requires Watering.
Absorbed Glass Mat (AGM) Micro-porous Glass Separators.
Flame Arresting Pressure Regulated Safety Valves.
UL Recognized Systems Component.
Positive Plates - Proprietary Lead Calcium Alloy- Negatives Plates - Lead Calcium.
Low Self Discharge Rate Approximately 1 % per month at 25° C (77° F).
Operational over a Wide Range of Temperatures, -40° C (-40° F) to +72° C (+160° F).
Classified as "Non-Spillable Battery" for Transport. Complies with DOT HMR49 Non-Hazardous Materials.
Battery Number wheelchair batteries ordered by battery number wheelchair batteries ordered by voltage Volts wheelchair batteries ordered by battery voltage Overall Dimensions wheelchair batteries ordered by weight Unit Wt wheelchair batteries ordered by weight wheelchair batteries ordered by nominal capacity Nominal wheelchair batteries ordered by nominal capacity
Capacity 1 wheelchair batteries ordered by nominal capacity Nominal wheelchair batteries ordered by nominal capacity
Capacity 2
wheelchair batteries ordered by length L wheelchair batteries ordered by length wheelchair batteries ordered by width W wheelchair batteries ordered by width wheelchair batteries ordered by height H wheelchair batteries ordered by height
CharimanBattery美国Chariman蓄电池总代in mm in mm in mm Lbs Kgs
AGM-1234T 12 7.71 195.9 5.18 131.6 6.89 175.0 24 10.9 33 50
AGM-1240T 12 7.71 195.9 5.18 131.6 8.05 204.4 29 13.2 40 61
AGM-1248T 12 8.99 228.0 5.45 138.0 8.82 224.0 35 15.9 48 84
AGM-1255T 12 8.99 228.0 5.45 138.0 8.82 224.0 39 17.7 55 96
AGM-1265T 12 10.22 259.6 6.60 167.7 8.93 226.7 50 22.7 65 121
AGM-1280T 12 10.22 259.6 6.60 167.7 8.93 226.7 56 25.4 80 149
AGM-1285T 12 12.90 327.8 6.75 171.3 8.96 227.6 62 28.2 85 158
AGM-12100T 12 12.01 305.1 6.60 167.7 8.93 226.7 62 28.1 100 186
AGM-12148T 12 13.46 341.9 6.77 172.0 11.95 303.5 90 40.8 150 315
AGM-12210L 12 20.76 527.4 8.70 221.0 9.77 248.3 124 56.2 210 390
AGM-12255L 12 20.76 527.4 10.89 276.6 9.77 248.3 156 70.8 255 550
AGM-6100T 6 10.21 259.3 6.60 167.6 8.92 226.7 42 19.1 100 193
AGM-6220T 6 10.28 261.1 7.06 179.3 9.92 251.8 66 30 220 492
AGM-6300T 6 10.28 261.1 7.06 179.3 12.94 328.6 90 40.8 300 692
AGM-6400HT 6 11.64 295.7 6.95 176.5 15.73 399.4 119 54 400 950
AGM-2660T 2 10.28 261.1 7.06 179.3 9.92 251.8 69 31.3 660 1476
AGM-2900T 2 10.28 261.1 7.06 179.3 12.94 328.6 93 42.2 900 2076
AGM-21200HT 2 11.64 295.7 6.95 176.5 15.73 399.4 123 55.8 1200 2850
